Nokia 5310b XpressMusic LCD Screen Replacement
  1. Nokia 5310b XpressMusic LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the back cover down with your thumb.
    • *Note: the battery cover is not shown in this picture
  2. Nokia 5310b XpressMusic LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 5310b XpressMusic LCD Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the battery with a fingernail and remove it from its housing.
    • *Note: the battery may be replaced or repaired at this step
  3. Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 FIRST to remove the camera cover and two T6 screws, before removing the faceplate.
    • Use the Spudger to gently pry up the edges of the front face plate
    • At the center of the faceplate edge below the music keys there is a small latch on each side.
    Before doing this step, first remove the camera cover and the two t6 screws from the back (steps 5 and 6). Otherwise you will break the cover. This may be a factor only for some revisions (RM-304)
    s c - crwdns2934203:0crwdne2934203:0
  4. Nokia 5310b XpressMusic LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 5310b XpressMusic LCD Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the keypad from the bottom with either the spudger or your finger.
    • Note: at this time the keypad can be removed and replaced
  5. Nokia 5310b XpressMusic LCD Screen Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently unsnap the back camera cover from the phone.
    • Lift the cover from the phone after it is unsnapped.
  6. Nokia 5310b XpressMusic LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 5310b XpressMusic LCD Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the T6 torx screwdriver head to remove the 2 screws on either side of the camera
    • Flip over the phone and again us the T6 torx head to remove the 4 screws located at each corner of the white keypad base
  7. Nokia 5310b XpressMusic LCD Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclip the faceplate plug (ribbon) located in the lower left corner of the motherboard
  8. Nokia 5310b XpressMusic LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 5310b XpressMusic LCD Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Spudger to pry up the 2 metal clips located near the center of the motherboard on both the left and right
    • At this point the phone should come apart into 2 pieces, the motherboard/LCD screen and the faceplate
  9. Nokia 5310b XpressMusic LCD Screen Replacement, LCD Screen: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclip the ribbon plug located on the top of the LCD screen that connects it to the motherboard
Max Kirby
crwdns2935283:005/01/11crwdne2935283:0
518 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-14, Regan Spring 2011 crwdns2935289:0Cal Poly, Team 15-14, Regan Spring 2011crwdne2935289:0
CPSU-REGAN-S11S15G14
crwdns2917034:0crwdne2917034:0
Thank you much! As efficient & thorough as it gets!
REDACTED FREE PRESS - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 9,032
