Nokia 3310 3G Screen Replacement
  1. Nokia 3310 3G Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 3310 3G Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 3310 3G Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Screen Replacement, Frame: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 3310 3G Screen Replacement, Frame: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 3310 3G Screen Replacement, Frame: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Screen Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 3310 3G Screen Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 3310 3G Screen Replacement, Motherboard: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 3310 3G Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 3310 3G Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the motherboard removed, the only thing holding the screen into place is the snap plug on the back of the motherboard.
    • Using a spudger, leverage the top snap up to disconnect it (photo shows motherboard rotated 90 degrees counterclockwise).
Aaron LeBlanc
crwdns2935283:010/24/18crwdne2935283:0
753 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G3, Peak Fall 2018 crwdns2935289:0UMass Dartmouth, Team S3-G3, Peak Fall 2018crwdne2935289:0
UMASSD-PEAK-F18S3G3
If you can break the screen without taking it apart, then you must not be human
Feyrowan - crwdns2934203:0crwdne2934203:0
The Cylons are greeting you.
M. H. -
Thank you!
I dont have cash for a new one,
but i could fix my old one.
There was soup on the display inside,
cleaned it, screen is clear now.
Yeay!
fred - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 2,068
