Describes how to replace the screen of the Nokia 3300B.
Flip the Nokia 3300B over with the back-side facing towards you.
Gently press the button on the back of the battery cover to release the cover and slide up.
Lift the battery out of the back of the phone.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Gently push the blue tabs on the top of the phone out of their slots.
With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
With the screen still facing you, remove the blue faceplate.
Grab the sides of the keypad and lift it up vertically.
Using the Torx T6 bit of a Phillips precision screwdriver, remove the six screws on the phone's inner protective case, as seen in the picture.
Holding the phone with the screen facing you, remove the top half of the phone from the circuit board.
Hold the top half of the phone with the screen facing you.
Using a pair of tweezers, release the tabs holding the two distinct cases together.
Be sure to remove both casings so that the screen is facing down. This will ensure that the screen does not fall out of its case.
Tilt the casing back and the screen should fall out smoothly.
Replace the old screen with the new screen.
