Nokia 3300B Screen Replacement
    1. Nokia 3300B Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 3300B Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the Nokia 3300B over with the back-side facing towards you.
      • Gently press the button on the back of the battery cover to release the cover and slide up.
    2. Nokia 3300B Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 3300B Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the battery out of the back of the phone.
      • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
    1. Nokia 3300B Screen Replacement, Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 3300B Screen Replacement, Screen: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 3300B Screen Replacement, Screen: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently push the blue tabs on the top of the phone out of their slots.
      • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
      • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
    2. Nokia 3300B Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With the screen still facing you, remove the blue faceplate.
    3. Nokia 3300B Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 3300B Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grab the sides of the keypad and lift it up vertically.
      • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides, so the button's pin don't snap.
    4. Nokia 3300B Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 3300B Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 3300B Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the Torx T6 bit of a Phillips precision screwdriver, remove the six screws on the phone's inner protective case, as seen in the picture.
      • NOTE: Be sure to save these screws so the phone can be reassembled later.
    5. Nokia 3300B Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 3300B Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Holding the phone with the screen facing you, remove the top half of the phone from the circuit board.
    6. Nokia 3300B Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 3300B Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 3300B Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Hold the top half of the phone with the screen facing you.
      • Using a pair of tweezers, release the tabs holding the two distinct cases together.
      • The tabs are very fragile. Be gentle when releasing the tabs.
    7. Nokia 3300B Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Be sure to remove both casings so that the screen is facing down. This will ensure that the screen does not fall out of its case.
      • NOTE: The screen's part identification sticker is on the top back side of the screen. The screen will need to be replaced with the same orientation.
    8. Nokia 3300B Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Tilt the casing back and the screen should fall out smoothly.
      • Replace the old screen with the new screen.
Chris Colwell
crwdns2935283:004/13/10crwdne2935283:0
116 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-65, Johann Spring 2010 crwdns2935289:0Cal Poly, Team 18-65, Johann Spring 2010crwdne2935289:0
CPSU-JOHANN-S10S18G65
crwdns2936753:030crwdne2936753:0 94
crwdns2942667:0crwdne2942667:0 3,761
