Nokia 3.1 Battery Replacement
  1. Nokia 3.1 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, remove the SIM and SD card trays.
  2. Nokia 3.1 Battery Replacement, Open the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 3.1 Battery Replacement, Open the back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 3.1 Battery Replacement, Open the back cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Plastic Cards
    $2.99
    • Try to use a thin tool like a razor blade to start to pry open the back cover.
    • When you opened it up just a little bit put a plastic card or a plastic opening tool inside the gap.
    • Using the plastic tool slowly make your way around the back cover. You can also use a guitar pick or similar.
    • Hint: the back cover is attached to the body with several plastic noses as well as a thin strip of adhesive. The cover is quite flexible and sturdy.
  3. Nokia 3.1 Battery Replacement, Remove logic board cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 3.1 Battery Replacement, Remove logic board cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the seven Torx T5 screws from the logic board cover.
    • Remove the logic board cover.
    • Lift up the battery connector from the logic board.
  4. Nokia 3.1 Battery Replacement, Remove battery adhesive strips: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 3.1 Battery Replacement, Remove battery adhesive strips: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At the bottom end of the battery you will see two black ends of adhesive strips showing up from underneath the battery.
    • Slowly pull at those adhesive strip ends to be able to lift out the battery.
To reassemble your device, follow these instructions in reverse order. Also don’t forget some double-faced adhesive tape to fixate the new battery.
crwdns2935229:09crwdne2935229:0
Baschtl
crwdns2935283:012/02/12crwdne2935283:0
1.608 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 7,725
