In this guide, we outline how to unscrew and remove the front case from the Nokia 2630b. This grants access to the LCD screen cover and the keyboard.
Press and the release button on both sides of the battery cover. While holding down the release buttons pull the battery cover away from the phone
Pull out the battery by holding the top of the battery and tilting out.
Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
NOTE: Keep the screws in a safe place while you continue working.
Separate the front case from the back case using the iPod opener
NOTE: The keypad is a loose piece and may fall out
Remove screws using the same T5 screw bit to release the computer chip from the case
Carefully lift the black frame off the screen with your fingers
Carefully remove the computer chip and screen out of the black case with your fingers
The screen is attached to the motherboard by an orange ribbon
Carefully detach the ribbon from the motherboard using your fingers
Reattach new screen by connecting the orange ribbon to the computer chip
Place computer chip and screen back into black case
Carefully place keypad back in place
Snap the front case back in place with the bottom case with your fingers
Reassemble screws with microscrewdriver
To reassemble your device, follow these instructions in reverse order. Make sure to snap the new screen / front case securely into place.
Great guide :-) I have a Nokia 2630 too and people can no longer hear me on calls, even though I can hear them. Do you know what could be wrong? Do you think this is something I could fix myself? Thanks!
You could try getting a neodymium magnet and run it across the earpiece grill. In my father's case, a lot of metal powder was in there, pressing in the speaker membrane; the alternative is cleaning it (which does require opening the phone using Eric's very nice guide). The alternative to those is ordering an earpiece online - but usually those are really bad quality, so trying to fix the original one would be advisable
Darie H -
