Nokia 2128i Internal Clock Battery Replacement
  1. Nokia 2128i Internal Clock Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 2128i Internal Clock Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 2128i Internal Clock Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
  2. Nokia 2128i Internal Clock Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 2128i Internal Clock Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 2128i Internal Clock Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingernail, pry the back of the battery upwards and pull out.
  3. Nokia 2128i Internal Clock Battery Replacement, Faceplate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 2128i Internal Clock Battery Replacement, Faceplate: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 2128i Internal Clock Battery Replacement, Faceplate: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  4. Nokia 2128i Internal Clock Battery Replacement, Keypad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 2128i Internal Clock Battery Replacement, Keypad: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 2128i Internal Clock Battery Replacement, Keypad: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the faceplate removed, simply peel off rubber key pad and remove.
  5. Nokia 2128i Internal Clock Battery Replacement, Motherboard Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 2128i Internal Clock Battery Replacement, Motherboard Assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 2128i Internal Clock Battery Replacement, Motherboard Assembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  6. Nokia 2128i Internal Clock Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 2128i Internal Clock Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 2128i Internal Clock Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
  7. Nokia 2128i Internal Clock Battery Replacement, Internal Clock Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 2128i Internal Clock Battery Replacement, Internal Clock Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the logic board completely removed, gently pry out the internal clock battery from its housing.
Curtis Lutje
crwdns2935283:010/07/10crwdne2935283:0
43 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-8, Maness Fall 2010 crwdns2935289:0Cal Poly, Team 20-8, Maness Fall 2010crwdne2935289:0
CPSU-MANESS-F10S20G8
crwdns2942667:0crwdne2942667:0 3,496
