crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Nokia 2 (TA-1029)crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Nokia 2 Teardown, Prepare your tools: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare your tools before starting the repair.
    • I have a random multi-set screwdriver laying around, but it doesn't have T2 head.
  2. Nokia 2 Teardown, Pry open the back casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 2 Teardown, Pry open the back casing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the back casing with your fingernail or a plastic pick.
    • Once you disconnect the back casing, you can use a pry tool or some other kind of resistive tool to lift the back panel.
  3. Nokia 2 Teardown, Pay attention to the screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the seven screws with your T5 screwdriver.
    • These screws should be removed with your T2 screwdriver.
  4. Nokia 2 Teardown, Unscrew the screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 2 Teardown, Unscrew the screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Prepare your T5 screwdriver.
    • Unscrew as marked in Step 3.
  5. Nokia 2 Teardown, Remove the back of the inner casing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 2 Teardown, Remove the back of the inner casing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger or anything that is thin and sturdy (not a piece of paper).
    • A piece of paper is not ideal to remove the inner casing because it may rip. A ruler will also work.
    • Take your tool and place between the back cover and the device. Lift the tool until the motherboard is exposed.
    • Be careful when opening it! If you break the plastic, there is no way to reassemble it to make it new again.
  6. Nokia 2 Teardown, 1st part summary: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is the motherboard.
    • This is the big mammoth, the 4000mAH battery.
    • This is where our charging module sits.
    • This is the speaker itself.
    • This is where the Taptic Engine resides.
  7. Nokia 2 Teardown, Let's dig more in! Detach all flex cable in the phone: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 2 Teardown, Let's dig more in! Detach all flex cable in the phone: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before the moment of truth, let's detach more cables.
    • Do not break the flex cable. Damaging the flex cable may result in a non-working phone. Please be careful!
  8. Nokia 2 Teardown, Squeeze out the battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 2 Teardown, Squeeze out the battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudging tool (used on step 5), Remove the battery from the slit shown and cut it.
    • The second picture shows what it will look like.
  9. Nokia 2 Teardown, Make more of it!: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 2 Teardown, Make more of it!: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 2 Teardown, Make more of it!: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the process as shown in Step 7.
  10. Nokia 2 Teardown, Unscrew the screws on the motherboard and charging module: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 2 Teardown, Unscrew the screws on the motherboard and charging module: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To avoid further damage, remove the screws first.
    • If you do not remove the screw and just proceed to the removal, you will damage the board, resulting in your phone being irreversibly broken.
  11. Nokia 2 Teardown, 2nd summary: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The green marks the 1GB RAM made by SK hynix
    • The red marks the Qualcomm Snapdragon 212. Unfortunately, this chip only supports ARMv7 so you can only play a little bit of games
  12. Nokia 2 Teardown, Pry off the screen: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 2 Teardown, Pry off the screen: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an iOpener and a spudger to open it.
    • If you can't afford those like me, you can use a hair dryer and some cards.
    • If you pry it open improperly, the LCD screen inside may be cracked, thus you'll have to do screen replacement to reconstruct it.
  13. Nokia 2 Teardown, Summary: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here is the device fully broken down.
Zean
crwdns2935283:007/20/21crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,134
