Nokia 1100b RH-36 Screen Replacement
    1. Nokia 1100b RH-36 Screen Replacement, Battery Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 1100b RH-36 Screen Replacement, Battery Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the phone over so that the screen faces down.
      • Press the gray button on the battery cover and slide it down off the back of the phone.
    2. Nokia 1100b RH-36 Screen Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
      • Gently pry the battery out of the phone.
    1. Nokia 1100b RH-36 Screen Replacement, Front Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 1100b RH-36 Screen Replacement, Front Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Firmly grip the back of the casing.
      • Separate the front and back casings either by pulling them apart from the middle or gently prying the front off with your fingers from the bottom.
      • Be sure not to bend the casing too much when prying from the bottom. Failure to do so may cause it to crack.
    1. Nokia 1100b RH-36 Screen Replacement, Inner Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 1100b RH-36 Screen Replacement, Inner Casing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
      • Remove the metal frame holding the screen and speaker.
    1. Nokia 1100b RH-36 Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 1100b RH-36 Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip over the metal frame you just removed.
      • Using the flat end of the spudger, pry apart the inner clear plastic frame with screen attached from the metal frame.
      • Remove the screen bearing plastic frame.
JSwan
crwdns2935283:004/12/13crwdne2935283:0
811 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-43, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 10-43, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S10G43
crwdns2935297:084crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,484
