crwdns2959928:0crwdne2959928:0 ↓If you have had troubles with the battery life of your phone and want to replace the battery, this guide will help you to access the battery and help you replace the battery step by step. If your phone will not turn on at all and you would like to make sure that the battery is fully intact, this guide will show you how to access the battery.
Using your thumbs, press and slide down the back cover of the Nokia 1010.
Insert the prying tool in the notch above the battery.
Once the prying tool is inserted, lift up the battery.
Instead of charging the battery the phone drains the battery how can I fix it
alfred ayegba - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
