Removing the front and back case will allow you access to other parts of this device.
            Turn over the device so that the back of the device is facing up.
            Insert the first plastic opening tool along the side to pry open the case.
            Use a second plastic opening tool to help separate the remaining seams.
            Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
            Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
            Remove the solar panel and circuit board from the front case.
