Nokero SunRay Pro Power Panel Capacitor Replacement
  1. Nokero SunRay Pro Power Panel Capacitor Replacement, Front and Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn over the device so that the back of the device is facing up.
  2. Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the first plastic opening tool along the side to pry open the case.
    • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
    • Use a second plastic opening tool to help separate the remaining seams.
  3. Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
    • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
  4. Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
    • Remove the solar panel and circuit board from the front case.
  5. Nokero SunRay Pro Power Panel Capacitor Replacement, Capacitor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the soldering station to desolder the two contact points around the connections of the capacitor to loosen the metal.
  6. Nokero SunRay Pro Power Panel Capacitor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the capacitor through the circuit board to remove it.
Nicholas Orr
crwdns2935283:001/20/15crwdne2935283:0
229 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-3, Blackwell Winter 2015 crwdns2935289:0USF Tampa, Team 9-3, Blackwell Winter 2015crwdne2935289:0
USFT-BLACKWELL-W15S9G3
crwdns2942667:0crwdne2942667:0 286
