Nokero N400 Switch Replacement
  1. Nokero N400 Switch Replacement, Remove Battery Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokero N400 Switch Replacement, Remove Battery Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokero N400 Switch Replacement, Remove Battery Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Switch Replacement, Unscrew Back Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokero N400 Switch Replacement, Unscrew Back Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Switch Replacement, Pry Open Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokero N400 Switch Replacement, Pry Open Back Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Switch Replacement, Remove Switch From Housing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger carefully pry switch from housing.
  5. Nokero N400 Switch Replacement, Cut Old Switch Free: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use wire cutters to cut the two black wires attached to the old switch.
    • You must use a splicer or a soldering gun to reattach the wires of the new switch.
    • If you splice the new switch wires together in the opposite order of the old switch wires, the new switch will still work.
Benjamin franklin
crwdns2935283:001/20/15crwdne2935283:0
USF Tampa, Team 19-2, Blackwell Winter 2015 crwdns2935289:0USF Tampa, Team 19-2, Blackwell Winter 2015crwdne2935289:0
USFT-BLACKWELL-W15S19G2
crwdns2942667:0crwdne2942667:0 230
