Nokero N400 Solar Panel Replacement
  1. Nokero N400 Solar Panel Replacement, Remove Battery Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokero N400 Solar Panel Replacement, Remove Battery Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokero N400 Solar Panel Replacement, Remove Battery Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Solar Panel Replacement, Unscrew Back Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokero N400 Solar Panel Replacement, Unscrew Back Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Solar Panel Replacement, Pry Open Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokero N400 Solar Panel Replacement, Pry Open Back Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Solar Panel Replacement, Solar Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokero N400 Solar Panel Replacement, Solar Panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the panel away from the rest of the assembly and cut the red and black wires coming from the panel
    • Be careful not to cut the ground-wire for the motherboard, it is the same color and goes to the exact same place as the solar panel wire.
    • For reassembly you will need to either splice, or solder the wires onto the replacement.
Daniel Bumiller
crwdns2935283:001/20/15crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 19-2, Blackwell Winter 2015 crwdns2935289:0USF Tampa, Team 19-2, Blackwell Winter 2015crwdne2935289:0
USFT-BLACKWELL-W15S19G2
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 228
