This guide will serve as a prerequisite guide to accessing the various components of your device and replacing the battery if your battery no longer recharges or will not hold a charge.
Press down firmly to remove the battery cover and display battery.
Then remove the battery.
Remove the 7mm Phillips #1 screw.
Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
Unlatch the clips on the inside and pull device apart.
