Noisy Percussion Massager Repair
  1. Noisy Percussion Massager Repair, Tools - #1 & #2 Phillips + thread locker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Thread lock can be found at any hardware store.
  2. Noisy Percussion Massager Repair, Remove the rear cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Noisy Percussion Massager Repair, Remove the rear cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist counter-clockwise very snug. It only moves about 1/4 of an inch - the second picture shows the slide lock slots.
  3. Noisy Percussion Massager Repair, Remove Two Screws from Housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There were actually two rubber plugs covering the screws that I had to work out… Not hard.
  4. Noisy Percussion Massager Repair, Open It Up: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Noisy Percussion Massager Repair, Open It Up: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Noisy Percussion Massager Repair, Open It Up: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Case opens pretty easy but you can see there are two tabs toward the back of the case … if it sticks, a simple pinch might help you open it up.
  5. Noisy Percussion Massager Repair, Remove screw - Apply Thread Lock - Re install: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Noisy Percussion Massager Repair, Remove screw - Apply Thread Lock - Re install: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Noisy Percussion Massager Repair, Remove screw - Apply Thread Lock - Re install: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert wisdom here.
  6. Noisy Percussion Massager Repair, Re-assemble the case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Noisy Percussion Massager Repair, Re-assemble the case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Surprising how much noise a loose screw can cause.
jtalbin
crwdns2935283:007/22/12crwdne2935283:0
313 crwdns2915208:0crwdne2915208:0
crwdns2947412:09crwdne2947412:0
Where can I buy a gasket, for the Recovery Pro massager, that is worn out? Thank you.
Emilia Cirstea - crwdns2934203:0crwdne2934203:0
We were unable to twist off the back on Step 2. Going to be returned to Costco since I can't fix it....
Richard DalCanto - crwdns2934203:0crwdne2934203:0
I have model 11mg0811 it has no screws on the sides and I it will not twist off ,when it's on it makes a lot of noise,I don't want to return it to COSTCO IS THERE SOMEWHERE I CAN TAKE IT,
Ted - crwdns2934203:0crwdne2934203:0
I've not found any shops locally that take these for repair. After looking at the pictures for the model 11MG0811 it appears that access to the inner workings is similar to an electronic toothbrush that uses a pinch/lock approach which can be quite a bit tougher.
jtalbin -
crwdns2936753:030crwdne2936753:0 127
crwdns2942667:0crwdne2942667:0 12,371
