You will be able to use this guide to successfully replace a faulty speaker on your tablet. To do so, you will need to disassemble your tablet and use soldering tools.
Look towards the topside of the tablet, where the power button is located.
Insert a plastic opening tool in the crack between the two parts of the case.
Move it gently back and forth to open the case.
With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
Remove the tape holding the battery in place.
Insert the flat end of the spudger tool in the crack beneath the battery.
Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
After the battery is unglued, locate the cables that connect it to the motherboard.
Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
Remove the tape holding the speaker in its socket.
After you remove the tape, remove the speaker from its socket. You can place the speaker on one side of the tablet to have more freedom.
Look for the place where the speaker's cables meet with the motherboard.
Use a soldering iron to desolder the cables and extract the solder using a desoldering braid.
How can I restore the memory on these tablets - were having problems with this tablet please help us
annievvtait07 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This is my favourite online game mahjong games online i have some time play.
conor mcgregor - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
