Remove 4 4.5mm Phillips head screws from back side of watch using PH00 Phillips head.
Unclip 5 latches from motherboard using a spudger.
Remove 2 3.0mm Phillips screws from motherboard using PH00 Phillips head.
Carefully remove motherboard & internal screen.
Remove 4 7.0mm hex-screws from front of watch using H1.5 Hex head.
Remove outer screen frame from front of watch.
Remove 4 4.5mm Phillips gold screws from back of watch using PH00 Phillips head.
Remove outer protective screen.
Replace outer protective screen with the new part.
But can you even buy replacement screen
Where can you buy a replacement screen?
