Nissan 350Z Tail Light Replacement
  1. Nissan 350Z Tail Light Replacement, Nissan 350Z Tail Light: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unlock and open the trunk.
    • The button is located right above your license plate.
  2. Nissan 350Z Tail Light Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nissan 350Z Tail Light Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Look for the 3 bolts that secure the tail light to the car.
    • Attach your 10MM socket to your 1/4 inch ratchet.
  3. Nissan 350Z Tail Light Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nissan 350Z Tail Light Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your 10MM socket and 1/4 inch ratchet remove the three bolts.
    • Make sure to keep the bolts together and in a safe place.
  4. Nissan 350Z Tail Light Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold both ends of the headlight and carefully remove the assembly.
    • You may need to use some force when pulling, as dowel pins secure it to the car.
    • You can flip the tail light over and place it in the tail light cavity so you do not have to hold it.
  5. Nissan 350Z Tail Light Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nissan 350Z Tail Light Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nissan 350Z Tail Light Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Check the underside of the connector for a square-shaped slot.
    • Insert your flathead screwdriver into the square tab to disconnect the connector.
    • If you are having trouble with this part, try to push the tab in then down.
  6. Nissan 350Z Tail Light Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nissan 350Z Tail Light Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reconnect the tail light cable connector to the new tail light assembly.
    • Press the connector firmly into the socket to ensure a secure connection.
  7. Nissan 350Z Tail Light Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the dowel pins to allow the light assembly to seat itself safely.
  8. Nissan 350Z Tail Light Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nissan 350Z Tail Light Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Replace the bolts and use your hand to tighten the bolt just a bit.
    • Use a ratchet with the 10 mm socket to tighten the bolts fully.
    • Avoid overtightening the bolts, as this can make it harder to remove them the next time you need to replace the tail light.
sddale
crwdns2935283:005/12/25crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
UC Davis, Team 3-7, Whithaus Spring 2025 crwdns2935289:0UC Davis, Team 3-7, Whithaus Spring 2025crwdne2935289:0
UCD-WHITHAUS-S25S3G7
crwdns2942667:0crwdne2942667:0 59
