Nintendo Wii U Fan Replacement
  1. Nintendo Wii U Fan Replacement, Remove Stickers Covering Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a flathead screwdriver, spudger, or tweezers, remove the stickers covering the screws on the bottom of the Wii U and on the side of the Wii U.
    • Do not try to use your fingernails. It would only hurt.
  2. Nintendo Wii U Fan Replacement, Unscrew All of the Screws on the Back of the Wii U: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii U Fan Replacement, Unscrew All of the Screws on the Back of the Wii U: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii U Fan Replacement, Unscrew All of the Screws on the Back of the Wii U: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove three Phillips screws with a Phillips #00 screwdriver.
    • Remove three Tri-Wing screws with a Y1 Tri-Wing screwdriver.
  3. Nintendo Wii U Fan Replacement, Remove the Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii U Fan Replacement, Remove the Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the battery, unscrew the screw holding it in place with a Phillips #00 screwdriver.
    • Then pull the battery free.
    • Once you reassemble the Wii U, you might need to set the date and time.
  4. Nintendo Wii U Fan Replacement, Unscrew the Screws on the Side of the Wii U: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii U Fan Replacement, Unscrew the Screws on the Side of the Wii U: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two screws on the side of the Wii U near the air vents with a Phillips #00 screwdriver.
    • EDIT 9/26/16: There are stickers covering these screws too. Remove them.
  5. Nintendo Wii U Fan Replacement, Pull off the Side Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii U Fan Replacement, Pull off the Side Cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii U Fan Replacement, Pull off the Side Cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the side cover to your right.
    • Lift the side cover off.
  6. Nintendo Wii U Fan Replacement, Unscrew the Screws Under the Side Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  7. Nintendo Wii U Fan Replacement, Removing the Top Cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii U Fan Replacement, Removing the Top Cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii U Fan Replacement, Removing the Top Cover: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the top cover.
    • Pull the top cover towards you.
    • Do not lift the top cover up all the way at first! Make sure to pull it towards you (shown in picture #2 and the video on the next step), then lift it up all the way. If you don't remove the top cover this way, U may damage your U. ):
    • Video of removing the top cover.
  8. Nintendo Wii U Fan Replacement, Removing the Fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii U Fan Replacement, Removing the Fan: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii U Fan Replacement, Removing the Fan: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two Phillips screws securing the fan in place with a Phillips #00 screwdriver.
    • Use a magnet or a magnetic screwdriver to lift up the screws once they're fully loosened, as seen in the second picture.
    • Screwdrivers with a black tip usually mean that they're magnetic, as shown with the black arrow in the second picture.
    • Remove the fan from its socket.
    • Set the fan's wires free from under the clamp (see the yellow box on picture #3).
    • Unplug the fan's power cable by tugging on its wires.
    • Do not tug the fan.
    • Do not tug the wires from too far or else the wires/power connector may break.
Congrats if you've made it this far! Click the button below if you successfully replaced your fan! To reassemble your Wii U, follow these instructions in reverse order. Note that you will not be able to put the stickers back on that were covering the screws on the bottom cover of the Wii U — well, who really cares about a sticker covering a screw!?
Thank you all for viewing this guide. Keep on fixing!
crwdns2935229:038crwdne2935229:0
Reid Fleishman
crwdns2935283:002/12/16crwdne2935283:0
1 552 crwdns2915208:0crwdne2915208:0
crwdns2947412:08crwdne2947412:0
Is it red = +5V, black = GND, grey = ¿PWM? - can't find original fan to buy [don't want to order from overseas] so trying to go with a 40mm 5V replacement, reusing the original connector.
facebook - crwdns2934203:0crwdne2934203:0
No that doesn't seem right. If someone knows the pinout with some certainty, please do tell.
facebook -
Here’s the fan pinout if someone’s going to splice in a new 40mm fan while reusing the original connector:
Black - Ground
Red - RPM signal
Grey - +5V
Ran across the pinout while splicing in a new 40mm fan because the original broke
Yevgney Sliosarenko - crwdns2934203:0crwdne2934203:0
so, has anyone had any luck with replacing the stock fan with a noctua fan? I’m gonna try it myself and see if its any quieter since the stock fan is really loud
Joshua Bishell - crwdns2934203:0crwdne2934203:0
No luck for me with Noctua fan unfortunately. But I suspect some defect with the WiiU itself. All fans always run at full blast for me. Tried Noctua, and Aliexpress replacement part which looks like original also same color wires.
facebook -
Did you ever do the noctua swap? I'm thinking about trying/doing it myself and curious to know if it worked?
animalrescuesussex -
This is a link to the fan I bought on Amazon. I used this guide and my WiiU works like new! https://www.amazon.com/gp/aw/d/B07KK4MPF...
Samantha Costello - crwdns2934203:0crwdne2934203:0
I used this guide to remove and blow the dust out of the fan. I'm surprised it wasn't actually that dirty.
Incineroar2296 - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 52
crwdns2936753:030crwdne2936753:0 255
crwdns2942667:0crwdne2942667:0 22,333
