Nintendo Wii Remote Speaker Replacement
  1. Nintendo Wii Remote Speaker Replacement, Front Cover Plate and Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote Speaker Replacement, Front Cover Plate and Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    my battery cover is different. The batteries are attached to the actual cover and come out when the back is removed.
    Kim Pearson - crwdns2934203:0crwdne2934203:0
  2. Nintendo Wii Remote Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Mine is not opening like a book? What do I do?
    Micah Thompson - crwdns2934203:0crwdne2934203:0
    It stops short of explaining replacing rechargeable battery. Unless you’re referring to the AA’s which don’t involve removing cover
    Sticky Insides - crwdns2934203:0crwdne2934203:0
  5. Nintendo Wii Remote Speaker Replacement, Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote Speaker Replacement, Speaker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote Speaker Replacement, Speaker: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the plastic opening tool between the edge of the speaker and the wii remote.
    • Gently lift the speaker out of the body of the Wii remote.
    In my Wii controller, the speaker is connected to two cables instead of touching the motherboard.
    Santi12008 - crwdns2934203:0crwdne2934203:0
Emily
crwdns2935283:004/14/13crwdne2935283:0
1.854 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-44, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 3-44, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S3G44
crwdns2935297:028crwdne2935297:0
Thank you, u help me to fix it.
joon lew - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 97
crwdns2942667:0crwdne2942667:0 7,627
