Nintendo Wii Remote Motherboard Replacement
  1. Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    my battery cover is different. The batteries are attached to the actual cover and come out when the back is removed.
    Kim Pearson - crwdns2934203:0crwdne2934203:0
  2. Nintendo Wii Remote Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Mine is not opening like a book? What do I do?
    Micah Thompson - crwdns2934203:0crwdne2934203:0
    It stops short of explaining replacing rechargeable battery. Unless you’re referring to the AA’s which don’t involve removing cover
    Sticky Insides - crwdns2934203:0crwdne2934203:0
  5. Nintendo Wii Remote Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the connector port, gently lift the motherboard about 2 cm from the base.
    • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
  6. Nintendo Wii Remote Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the edges of the motherboard and pull it straight away from the case.
crwdns2935229:032crwdne2935229:0
Emily
crwdns2935283:004/14/13crwdne2935283:0
1.854 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-44, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 3-44, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S3G44
crwdns2935297:028crwdne2935297:0
crwdns2947412:07crwdne2947412:0
Where do you find a motherboard and how much do they typically cost?
Jeff - crwdns2934203:0crwdne2934203:0
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Lisa Cole - crwdns2934203:0crwdne2934203:0
Where can i buy a brand new and original (not fake of course) wii remote for $20?
arttitudesign -
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
Darren Woloshyn - crwdns2934203:0crwdne2934203:0
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Michael baldwin - crwdns2934203:0crwdne2934203:0
Just adding a comment to dispute the above suggestion that “this is useless”. I used this guide to help repair a damaged Wii Controller which had had some battery leakage onto the mainboard. I was able to open the controller, clean up (using vinegar and water) the battery corrosion and re-assemble the controller. It works fine again now and I used this guide to find out that there are plastic clips holding the case together.
Sylph Hawkins - crwdns2934203:0crwdne2934203:0
I can't sync my Wii balance board. and remote at the same time. when the Wii remotes sync the balance board goes out and vice versa
Geraldine Cartagena - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 65
crwdns2936753:030crwdne2936753:0 264
crwdns2942667:0crwdne2942667:0 35,278
