Nintendo Wii Remote Main Buttons Replacement
crwdns2869540:0crwdne2869540:0: 51K
14
77
349
50,515
crwdns2955950:0crwdne2955950:0: 8
crwdns2960004:03crwdne2960004:0, crwdns2960008:05crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 27
crwdns2959974:027crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 10
crwdns2959982:010crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 5 - 10 crwdns2931279:0crwdne2931279:0
crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
Removing the main buttons requires opening the device. The main buttons include all buttons except the trigger style B button.
    1. Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the Wii Remote over so the battery cover faces you.
      • Push up on the bottom tab.
      • Remove the battery cover.
    2. Nintendo Wii Remote Main Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the first battery by pressing down on the positive end and pulling the battery out.
      • Remove the second battery by pushing up on the positive end and pulling the battery out.
    3. Nintendo Wii Remote Main Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
      • Repeat with the two bottom screws.
    4. Nintendo Wii Remote Main Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote Main Buttons Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
      • These tabs are breakable. However, if the tabs are broken the controller will still function.
      • Open the front plate like a book.
      • Small parts may fall out as you open the front plate.
    1. Nintendo Wii Remote Main Buttons Replacement, Main Buttons: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote Main Buttons Replacement, Main Buttons: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Working on the inside of the front cover, peel off the three rubber pads covering the buttons.
    2. Nintendo Wii Remote Main Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip over the cover, allowing the buttons to fall into your hand.
      • Be ready to catch all the buttons, some are very small. If a button does not fall out apply gentle pressure from behind.
      • When reassembling, put each plastic button in its allocated slot. Each button only fits snugly in one slot.
      • The best option for you is rotate the Wii Controller by 180°. If you obey this note, the small parts wont fall off and then you can remove the buttons.
crwdns2935229:027crwdne2935229:0
Emily
crwdns2935283:004/14/13crwdne2935283:0
2,030 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-44, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 3-44, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S3G44
crwdns2947412:05crwdne2947412:0
Where did you get your replacement buttons? I can't find them online anywhere...
devannedloss - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
2024 and can't find them online ANYWHERE! I'm hoping a WiiUDpad fits on the wiimote. You'd think there'd be a bunch of wiimote shells of different colours available everywhere online, but they're nowhere to be found
how frustrating!
MartianIsotopes - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Vinted is full of them. Although some people ask wayyy too much for them!
Sophie Nicholson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yo tampoco los encuentro por ninguna parte
kinoto taller - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 77
crwdns2936753:030crwdne2936753:0 349
crwdns2959996:0crwdne2959996:0 50,515
