Nintendo Wii Remote B Trigger Button Replacement
crwdns2869540:0crwdne2869540:0: 21K
6
42
179
21.194
crwdns2955950:0crwdne2955950:0: 3
crwdns2960004:03crwdne2960004:0.
crwdns2959984:0crwdne2959984:0: 5
crwdns2959974:05crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 9
crwdns2959982:09crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 15 - 20 crwdns2931279:0crwdne2931279:0
crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
The B button can malfunction or get misaligned due to improper or over use. Installing the B button requires disassembly of the entire device. This means removing the front cover plate, and the motherboard.
    1. Nintendo Wii Remote B Trigger Button Replacement, Front Cover Plate and Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote B Trigger Button Replacement, Front Cover Plate and Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the Wii Remote over so the battery cover faces you.
      • Push up on the bottom tab.
      • Remove the battery cover.
    2. Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the first battery by pressing down on the positive end and pulling the battery out.
      • Remove the second battery by pushing up on the positive end and pulling the battery out.
    3. Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
      • Repeat with the two bottom screws.
    4. Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
      • These tabs are breakable. However, if the tabs are broken the controller will still function.
      • Open the front plate like a book.
      • Small parts may fall out as you open the front plate.
    1. Nintendo Wii Remote B Trigger Button Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote B Trigger Button Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the connector port, gently lift the motherboard about 2 cm from the base.
      • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
    2. Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grasp the edges of the motherboard and pull it straight away from the case.
    1. Nintendo Wii Remote B Trigger Button Replacement, B Trigger Button: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote B Trigger Button Replacement, B Trigger Button: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the black sensor screen found at the bottom end of the Wii remote.
      • Grip the free edge of the black sensor screen and gently pull it down to remove from the Wii control.
    2. Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Find the two small tabs near the front end of the white plastic housing.
      • Place the flat end of the spudger tool under one tab and lightly push up until the tabs pop out of place.
    3. Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the remote over and the plastic B trigger will fall out.
      • Catch the plastic trigger so it does not get lost.
    4. Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the motherboard so that the rumble motor and the white plastic housing face up.
      • Place the flat end of the spudger tool under the round rumble motor and lightly push up.
      • Tilt the motherboard to the left and the rumble motor will fall out of the white housing.
      • Do not pull the rumble motor out, this could cause the wires to rip from the motherboard.
    5. Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the motherboard over and locate the two white tabs at the top the plastic housing.
      • Place both thumbs on the inside of the tabs and push the tabs outward.
      • Use the inner sides of your thumbs to separate the motherboard from the plastic housing.
    6. Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Remote B Trigger Button Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently push the rubber button out of the plastic housing.
      • The rubber button is bouncy, so be cautious after pushing it out.
crwdns2935229:05crwdne2935229:0
Emily
crwdns2935283:004/14/13crwdne2935283:0
2.030 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-44, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 3-44, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S3G44
crwdns2936753:07crwdne2936753:0 42
crwdns2936753:030crwdne2936753:0 179
crwdns2959996:0crwdne2959996:0 21,194
