Nintendo Wii Fan Replacement
  1. Nintendo Wii Fan Replacement, Faceplate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Fan Replacement, Faceplate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
  3. Nintendo Wii Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Nintendo Wii Fan Replacement, Outer Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii Fan Replacement, Outer Case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii Fan Replacement, Outer Case: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Nintendo Wii Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Nintendo Wii Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Nintendo Wii Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Nintendo Wii Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Point screw
  12. Nintendo Wii Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Nintendo Wii Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
    • You may use a 4 mm hex driver to extend your bit into the recesses and reach the screws.
  14. Nintendo Wii Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the outer case straight up off the body of the Wii.
  15. Nintendo Wii Fan Replacement, Fan: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the fan connector with a pair of tweezers and lift it straight up and out of its socket on the motherboard.
    • Be sure your tweezers are clamped down on the fan connector, not the socket attached to the motherboard.
  16. Nintendo Wii Fan Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
  17. Nintendo Wii Fan Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan from the Wii.
crwdns2935229:032crwdne2935229:0
crwdns2947412:09crwdne2947412:0
Awesome guide, just replaced faulty fan unit in my 9 year old wii. Should hopefully keep it going for another 9 years :)
Finlay Macrae - crwdns2934203:0crwdne2934203:0
Super easy and great instructions! I feel a little guilty that my Wii sat in the garage for 4 years! Now it'll be a great birthday present for my 2 boys.
e_gayheart - crwdns2934203:0crwdne2934203:0
Does anyone have a diagram for the Wii’s airflow? I’m looking to install a booster fan at the bottom to help blow air in but I want to make sure it is effective.
Jessica Parnelli Fawkes - crwdns2934203:0crwdne2934203:0
nice¡¡¡¡¡¡¡¡¡¡¡¡¡¡
RIGO NOLASCO - crwdns2934203:0crwdne2934203:0
Thanks! Wii Quarantine’n in 2021!
Daniel Thomas - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 41
crwdns2936753:030crwdne2936753:0 211
crwdns2942667:0crwdne2942667:0 45,784
