Use this guide to replace your Wii's faceplate. Replacing the faceplate will provide new blue LEDs that light up around the optical drive opening.
Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
crwdns2935229:026crwdne2935229:0
Any more to do if pressing the on button does nothing, its still red power light?
Kyrre - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Tanks for this guide Btw
Thanks for the guide, I just wish it continued with replacing the components within the faceplate, as I wanted to replace the white shell. Still helpful though!
Cynthia - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
