Nintendo Wii DVD Drive Replacement
crwdns2869540:0crwdne2869540:0: 40万
67
401
1,898
395,930
crwdns2955950:0crwdne2955950:0: 256
crwdns2960004:0149crwdne2960004:0, crwdns2960008:0107crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 470
crwdns2959974:0470crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 147
crwdns2959982:0147crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 1 - 2 crwdns2931253:0crwdne2931253:0
crwdns2862627:0crwdne2862627:0
crwdns2862628:0crwdne2862628:0
Use this guide to replace a broken DVD drive. Depending on your new part, you may have to swap out the four rubber grommets on the DVD drive housing.
crwdns2959948:0crwdne2959948:0
crwdns2959952:0crwdne2959952:0
    1. Nintendo Wii DVD Drive Replacement, Faceplate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii DVD Drive Replacement, Faceplate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
    2. Nintendo Wii DVD Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
    3. Nintendo Wii DVD Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
    4. Nintendo Wii DVD Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
    5. Nintendo Wii DVD Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
    6. Nintendo Wii DVD Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii DVD Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully pull the faceplate away from the front of the Wii.
      • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
      • Remove the faceplate.
    1. Nintendo Wii DVD Drive Replacement, Outer Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii DVD Drive Replacement, Outer Case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii DVD Drive Replacement, Outer Case: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Open the controller port cover until it is perpendicular to the black controller port bezel.
      • Pull the controller port cover straight up to release it from the outer case.
      • Repeat this procedure for the memory card port cover.
    2. Nintendo Wii DVD Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii DVD Drive Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
      • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
    3. Nintendo Wii DVD Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 5 mm Phillips screws above the controller ports.
    4. Nintendo Wii DVD Drive Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
    5. Nintendo Wii DVD Drive Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the following screws:
      • Two 5 mm Phillips screws
      • One 8.2 mm Tri-Point screw
    6. Nintendo Wii DVD Drive Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
    7. Nintendo Wii DVD Drive Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      iFixit Precision 4 mm Screwdriver Bit
      $2.99
      • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
      • You may use a 4 mm hex nut driver to extend your bit into the recesses and reach the screws.
    8. Nintendo Wii DVD Drive Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the outer case straight up off the body of the Wii.
    1. Nintendo Wii DVD Drive Replacement, DVD Drive: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii DVD Drive Replacement, DVD Drive: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the small Phillips screw securing the battery door to the bottom panel.
      • This screw is captive to the battery door.
      • Pull the battery door out of the Wii.
      • The system time will be reset once you remove the battery door.
      • This is a good time to change the CR2032 battery if it hasn't been changed recently.
    2. Nintendo Wii DVD Drive Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 8.2 mm Tri-Point screw that was hidden beneath the battery door.
    3. Nintendo Wii DVD Drive Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 8.2 mm Tri-Point screws securing the DVD drive shield near the controller ports.
    4. Nintendo Wii DVD Drive Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Be cautious as you remove the DVD shield, the edges are sharp and could cut you
      • Lift the DVD drive shield upward and remove it from the Wii.
    5. Nintendo Wii DVD Drive Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 9 mm Phillips screws securing the DVD drive to the bottom panel.
    6. Nintendo Wii DVD Drive Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
      • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
    7. Nintendo Wii DVD Drive Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the DVD drive power cable away from its socket on the DVD drive.
    8. Nintendo Wii DVD Drive Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii DVD Drive Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
      • Be sure you are prying up on the retaining flap, not the socket itself.
      • Pull the DVD drive ribbon cable out of its socket.
      • Remove the DVD drive from the Wii.
    1. Nintendo Wii DVD Drive Replacement, DVD Drive: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Wii DVD Drive Replacement, DVD Drive: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Wii DVD Drive Replacement, DVD Drive: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The following steps are only necessary if your replacement Wii DVD drive does not include the four rubber grommets along the front and rear of the DVD drive housing.
      • Insert the tip of a long, skinny screwdriver into the hole in the center of the first grommet on the rear of the DVD drive housing.
      • Pull the grommet straight away from the DVD drive housing until it is free.
    2. Nintendo Wii DVD Drive Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Repeat the procedure described in the preceding step for the second rubber grommet on the rear of the DVD drive housing.
    3. Nintendo Wii DVD Drive Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii DVD Drive Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Set the DVD drive on its side, with the two rubber grommets along the front of the drive facing you.
      • Insert the end of the skinny screwdriver into the hole in the center of the lower rubber grommet along the front of the DVD drive housing.
      • Pull the screwdriver straight up until the grommet is free.
    4. Nintendo Wii DVD Drive Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Wii DVD Drive Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Rotate the DVD drive housing 180 degrees so that it is resting on the side opposite that of the previous step.
      • Repeat the procedure in the preceding step to remove the second rubber grommet along the front of the DVD drive housing.
crwdns2935229:0470crwdne2935229:0
David Hodson
crwdns2935283:004/13/10crwdne2935283:0
157,267 crwdns2915208:0crwdne2915208:0
crwdns2935297:0127crwdne2935297:0
crwdns2947412:0107crwdne2947412:0
Brilliant guide. I had the drive swapped in 10 mins and my son is over the moon.
Patrick Anderson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My Wii stopped reading disks and there was a bad clicking noise when trying to read disks. I swapped it out with a new one by following this guide and it works perfectly now! I could not be more pleased. Great guide!
adamhuttonc - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This was exact and awesome. I ordered a drive online and installed it using these very exact and useful instructions. worked perfectly, and two little people are quite happy. Thanks again.
markstewart73 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Excellent Guide!! Very descriptive.
billyf0486 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 67
crwdns2936753:07crwdne2936753:0 401
crwdns2936753:030crwdne2936753:0 1,898
crwdns2959996:0crwdne2959996:0 395,930
