Nintendo WaveBird Wireless Controller Motherboard Replacement
crwdns2869540:0crwdne2869540:0: 1万
3
26
138
10,113
crwdns2959984:0crwdne2959984:0: 8
crwdns2959974:08crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: 15 - 20 crwdns2931279:0crwdne2931279:0
crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
This guide will show you the steps on installing the motherboard. This will be helpful if the controller won't turn on or if it turns on and doesn't work.
    1. Nintendo WaveBird Wireless Controller Motherboard Replacement, Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo WaveBird Wireless Controller Motherboard Replacement, Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull down on the battery cover release lever and pull back to remove the cover.
    2. Nintendo WaveBird Wireless Controller Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove both batteries from the device.
    1. Nintendo WaveBird Wireless Controller Motherboard Replacement, Front Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo WaveBird Wireless Controller Motherboard Replacement, Front Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
      • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
    2. Nintendo WaveBird Wireless Controller Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo WaveBird Wireless Controller Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully turn over the controller and place it on a flat surface.
      • Slowly separate the top panel from the bottom panel.
      • The buttons are loose and may fall off the motherboard.
      • Once separated, set aside the top panel.
      • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
    1. Nintendo WaveBird Wireless Controller Motherboard Replacement, Buttons: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo WaveBird Wireless Controller Motherboard Replacement, Buttons: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo WaveBird Wireless Controller Motherboard Replacement, Buttons: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use tweezers to remove the buttons.
      • It may be easier to remove the A button off of the pad by lifting it with your fingers.
      • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
    1. Nintendo WaveBird Wireless Controller Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using tweezers remove the three grey button pads from the motherboard.
    2. Nintendo WaveBird Wireless Controller Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With your fingers gently grip the motherboard on both sides and lift it away from the back panel.
      • To put the motherboard back into place, align the two metal clips under the motherboard with the slots in the back panel. The motherboard should fall into place.
crwdns2935229:08crwdne2935229:0
Travis Taylor
crwdns2935283:004/12/13crwdne2935283:0
563 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-40, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 10-40, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S10G40
crwdns2935297:0180crwdne2935297:0
crwdns2936753:030crwdne2936753:0 138
crwdns2959996:0crwdne2959996:0 10,113
