crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
crwdns2959928:0crwdne2959928:0 ↓This guide will show you the steps on installing the joystick. This will be helpful if the joystick isn't working properly.
Pull down on the battery cover release lever and pull back to remove the cover.
Remove both batteries from the device.
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
Carefully turn over the controller and place it on a flat surface.
Slowly separate the top panel from the bottom panel.
Once separated, set aside the top panel.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove the buttons.
Grab the base of the grey joystick cover with one hand and firmly hold down the rest of the controller with the other hand.
Pull off the grey joystick cover.
crwdns2935229:09crwdne2935229:0
Question. My wavebird joystick wobbles a lot and gets stuck in directions I’m not inputting. Will replacing the top of the stick fix this? Or would I have to solder a new analog stick to the board?
Golgamang - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
