crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
crwdns2959928:0crwdne2959928:0 ↓The Nintendo WaveBird Wireless Controller uses radio frequency (RF) technology to connect to the Nintendo GameCube Console wirelessly.
Should your WaveBird Controller C-stick (the yellow “joystick” located on the righthand side of the controller with the letter C on top of the button) need replacement or repair from wear and tear or malfunction, this guide will show you the steps necessary for removing and reassembling a C-stick.
This repair will be helpful if the C-Stick isn't working properly.
Comfortability with the handling of a controller motherboard and skilled use of tweezers and a Tri-point Y1 screwdriver are necessary skills required.
There is potential for device damage to the motherboard and daughterboard of the controller during this repair, and this guide further explains the careful steps necessary to prevent damage below.
Spudger4.9
Pull down on the battery cover release lever and pull back to remove the cover.
Remove both batteries from the device.
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
Carefully turn over the controller and place it on a flat surface.
Slowly separate the top panel from the bottom panel.
Once separated, set aside the top panel.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove the buttons.
Grab the base of the yellow C-Stick cover with one hand and gently hold down the bottom piece of the motherboard with the spudger.
Pull off the yellow C-Stick cover.
