Nintendo Switch Right Joy-Con Shell Replacement
crwdns2869540:0crwdne2869540:0: 12万
46
201
864
115,844
crwdns2955950:0crwdne2955950:0: 22
crwdns2960004:013crwdne2960004:0, crwdns2960008:09crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 75
crwdns2959974:075crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 23
crwdns2959982:023crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:045crwdne2931287:0 - crwdns2931291:02crwdne2931291:0
After heavy use or excessive force, the Nintendo Switch Joy-Con casing may become worn or cracked. This may expose the Joy-Cons’ electronics, putting them at risk for further damage. However, Joy-Cons may remain functional without a new shell. We suggest replacing the shell before you have to buy a new pair of Joy-Cons. If you wish to fix a worn Switch casing, use this guide to replace the right Joy-Con shell.
Note that the procedure for repairing the Left Joy-Con is different.
Though replacing a Joy-Con shell involves only unscrewing and moving electronic parts, some steps require precision to re-attach small parts.
Because the Joy-Cons are separate from the main system, you do not have to turn off your Switch before replacing the Joy-Con shells.
    1. Nintendo Switch Right Joy-Con Shell Replacement, Right Joy-Con Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4 tri-point screws on the back of the Joy-Con.
      • These are the only tri-point screws on the Joy-Con. All other screws require a Phillips head screwdriver.
      • These screws are incredibly easy to strip. Apply constant downward pressure while unscrewing them.
    2. Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip open the back shell to expose the battery.
    3. Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the screw connecting the rail to the back shell.
    4. Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery and disconnect it from the motherboard. You may use tweezers or your hands to pull connections from the motherboard.
      • The battery may be difficult to remove due to adhesive. A spudger may help to detach it from the casing.
    5. Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Before performing the next step, take note of how the antenna cable is seated for proper reassembly.
      • Remove the small antenna chip (shown in second picture) and disconnect it from the motherboard.
    6. Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 3 screws holding the battery casing in the shell.
    7. Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the ribbon cables connecting the rail and battery casing to the motherboard. Unlock the cables by flipping the connector upwards with a spudger, then pull the cable out of the connector.
      • You may even choose to leave the rail connected, though it will be unwieldy.
      • Be careful not to lift the connectors in the wrong direction. The connection nearest to the shoulder buttons lifts up away from the rail (the black part), and the connection nearest to the rumble motor lifts in the opposite direction, up toward the rail (the thin grey part.)
    8. Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the rumble motor by disconnecting the white 2-pin connector.
    9. Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the black ZR button from the battery casing.
      • Remove the button sensor by unscrewing it from the battery casing.
    10. Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two Phillips screws holding the joystick to the motherboard.
      • Disconnect the joystick ribbon cable from the motherboard.
    11. Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two screws anchoring the motherboard to the shell.
    12. Nintendo Switch Right Joy-Con Shell Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Transfer all buttons to the replacement shell.
      • If any silicone button covers are missing, they may be stuck to the back of the motherboard.
crwdns2935229:075crwdne2935229:0
Matthew Cheney
crwdns2935283:001/16/20crwdne2935283:0
1,357 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S1-G8, Raign Spring 2020 crwdns2935289:0University of North Texas, Team S1-G8, Raign Spring 2020crwdne2935289:0
UNT-RAIGN-S20S1G8
crwdns2947412:09crwdne2947412:0
Not quite as thorough as the other Joy-con tear down but always a handy thing to have, going by the pictures it gave me all the information I needed personally concerning the screws, so I was able to strip the whole controller down and swap it into another shell. It is straight forward once you get in to it and have to give the author their much deserved credit for posting this up!
Lee Whittaker - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Very good detailed guide, only thing I would change is I’d probably take the rumble motor out right after of even before the battery. It’s pretty easy to remove, you can do it at anytime after opening, and it gets the wires out of the way to make other parts easier.
Dominic Garcia - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I am having difficulty removing the ribbon cable next to the rumble motor on step 7. It would be nice to have a photo of which way the clamp is expected to swing; I suspect I know the correct direction, but my tools are bending it instead.
earthexe - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
In fact, this step is unnecessary unless you are replacing the buttons or rail case. The rail may remain attached if you are only replacing the front, back, and middle casing.
*attention* the r button can be very easily broken off when removing the pcb. It requires soldering skills to re attach it afterward.
Tthat1guy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 46
crwdns2936753:07crwdne2936753:0 201
crwdns2936753:030crwdne2936753:0 864
crwdns2959996:0crwdne2959996:0 115,844
