This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$16.96
Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
Use a JIS 000 driver or an iFixit PH 000 driver to remove the following screws securing the back panel:
Two 3.6 mm-long screws on the top of the device
Two 3.6 mm-long screws on the bottom of the device
Insert an opening tool into the left speaker grille on the bottom of the device.
Twist the opening tool to release the clips securing the back panel.
Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
Insert an opening tool into the right speaker grille on the bottom of the device.
Twist the opening tool to release the clips.
Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
Lift the bottom edge of the back panel, opening it like a book.
Remove the back panel.
Use a JIS 000 driver or an iFixit PH 000 driver to remove the four screws securing the shield plate:
Three 3.1 mm screws
One 4.5 mm screw
Use a spudger or your fingers to lift the shield plate up and out of the device.
Remove the shield plate.
Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
