Nintendo Switch Front Frame Replacement
crwdns2869540:0crwdne2869540:0: 4万
41
139
639
39,599
crwdns2955950:0crwdne2955950:0: 204
crwdns2960004:0200crwdne2960004:0, crwdns2960008:04crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 29
crwdns2959974:029crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 5
crwdns2959982:05crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931291:02crwdne2931291:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
Use this guide to replace the front frame surrounding the midframe and containing the display.
The Switch uses JIS screws. A JIS 00 driver works best, but you can also use a JIS 000 driver. If you use a Phillips driver, you'll risk stripping the screws.
Note that due to the way guides are combined into a single sequence, occasionally a step may be repeated or a picture may show parts in place or absent that aren't related to the particular job being done. In those cases, simply follow the written instructions regarding the actual operation being performed and disregard things like whether the battery is in place or not, for example.
    1. Nintendo Switch Front Frame Replacement, Release the Joy Con controller locking tabs: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement, Release the Joy Con controller locking tabs: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement, Release the Joy Con controller locking tabs: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Before you begin this repair, make sure the device is completely powered off.
      • Press and hold down the small round button on the back of the Joy Con controller.
      • While you hold down the button, slide the controller upward.
    2. Nintendo Switch Front Frame Replacement, Remove the Joy Con controllers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement, Remove the Joy Con controllers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement, Remove the Joy Con controllers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Continue sliding the Joy Con upward until it's completely removed from the console.
      • Repeat this same process for the other Joy Con.
    3. Nintendo Switch Front Frame Replacement, Remove the back-side screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      Magnetic Project Mat
      $19.95
      • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
      • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
      • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
    4. Nintendo Switch Front Frame Replacement, Remove the top and bottom screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement, Remove the top and bottom screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a JIS 00 driver to remove the following screws securing the rear panel:
      • One 2.5 mm-long screw on the top edge of the device
      • Two 2.5 mm-long screws on the bottom edge of the device
      • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
      • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
    5. Nintendo Switch Front Frame Replacement, Remove the center side screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement, Remove the center side screws: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
    6. Nintendo Switch Front Frame Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your finger to flip up the kickstand on the back of the device.
      • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
    7. Nintendo Switch Front Frame Replacement, Remove the kickstand well screw: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
      • Close the kickstand.
    8. Nintendo Switch Front Frame Replacement, Remove the rear panel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement, Remove the rear panel: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement, Remove the rear panel: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Open the game card cartridge flap.
      • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
      • Lift the rear panel straight up from the bottom of the device and remove it.
      • Don't tilt it upwards while opening or else you risk breaking the plastic tabs on the top edge of the panel.
    1. Nintendo Switch Front Frame Replacement, Remove the microSD card reader: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
    2. Nintendo Switch Front Frame Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the flat end of a spudger to disconnect the microSD card reader press connector and lift straight up to remove it.
      • During reassembly, remove the foam pad before connecting the press connector to the motherboard. Set the foam pad back in place after you verify it's connected.
    3. Nintendo Switch Front Frame Replacement, Reassembly information: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement, Reassembly information: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement, Reassembly information: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • During reassembly:
      • Peel the foam block off the MicroSD card reader.
      • Carefully align the MicroSD card reader press connector over its socket on the board and press down to connect it.
      • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      • Set the foam block onto the connector and press it into place.
    1. Nintendo Switch Front Frame Replacement, Remove the shield plate: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a JIS 00 driver to remove the six 3 mm screws securing the shield plate to the device.
    2. Nintendo Switch Front Frame Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • If the console doesn't have this foam, skip this step.
      • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
      • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
    3. Nintendo Switch Front Frame Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      iFixit Thermal Putty
      $9.95
      • Insert a spudger underneath the shield plate along the edge of the device.
      • Pry up to lift the shield plate and remove it from the device.
      • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
      • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
      • During reassembly, if you don't have replacement thermal compound, use the flat end of a spudger to distribute the old compound evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate.
      • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
    1. Nintendo Switch Front Frame Replacement, Disconnect the battery: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement, Disconnect the battery: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the point of a spudger beneath the battery cable and slowly lift straight up to disconnect the flat‑topped battery connector from the board.
    1. Nintendo Switch Front Frame Replacement, Remove the heat sink: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a JIS 00 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    2. crwdns2935267:0crwdne2935267:0
      iFixit Adhesive Remover
      $19.99
      • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
      • The foam only needs to be peeled back enough to clear the fan.
      • The foam is really delicate and tears easily. Use the following technique to peel the foam:
      • If you have some, dip the point of a spudger in adhesive remover or isopropyl alcohol (90% or greater).
      • Insert the point of a spudger underneath a part of the foam that isn't stuck to anything.
      • Press the top of the foam with your finger to hold it in place.
      • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
    3. Nintendo Switch Front Frame Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
      • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
      • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly. Don't reuse the old thermal paste.
      • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
    1. Nintendo Switch Front Frame Replacement, Remove the headphone jack and game card reader: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement, Remove the headphone jack and game card reader: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
    2. Nintendo Switch Front Frame Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a pair of tweezers to slide the digitizer cable horizontally out of its connector on the game card reader board.
      • Before inserting the cable during reassembly, make sure the ZIF connector locking flap is flipped up.
      • With the cable parallel to the board, gently slide it into its connector.
      • Don't force the cable into the connector. If it doesn't insert, ensure the locking flap is flipped up, reposition the cable, and try again.
      • If your touchscreen doesn't work after the repair but your Game Card reader does, make sure this cable is properly inserted. If your Game Card reader also doesn't work, check the Game Card connector in the next step instead.
    3. Nintendo Switch Front Frame Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the point of a spudger to pry the headphone jack and game card reader connector straight up to disconnect it from the motherboard.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      • If the touch screen doesn't work and/or game cards aren't detected after reassembly, you might have not fully reconnected this press connector. Carefully disconnect it and try again.
    4. Nintendo Switch Front Frame Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a JIS 00 driver to remove the three 3.1 mm screws securing the headphone jack and game card reader board to the device.
    5. Nintendo Switch Front Frame Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a pair of tweezers or your fingers to remove the headphone jack bracket.
    6. Nintendo Switch Front Frame Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a pair of tweezers or your fingers to remove the headphone jack and game card reader board.
    1. Nintendo Switch Front Frame Replacement, Remove the motherboard: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement, Remove the motherboard: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the LCD ribbon cable ZIF connector.
    2. Nintendo Switch Front Frame Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a pair of tweezers to pull the ribbon cable straight out of its connector on the motherboard.
    3. Nintendo Switch Front Frame Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the fan cable ZIF connector.
    4. Nintendo Switch Front Frame Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a pair of tweezers to pull the fan cable straight out of its connector on the motherboard.
    5. Nintendo Switch Front Frame Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the power and volume button ribbon cable ZIF connector.
    6. Nintendo Switch Front Frame Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    7. Nintendo Switch Front Frame Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the smaller LCD ribbon cable ZIF connector.
    8. Nintendo Switch Front Frame Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    9. Nintendo Switch Front Frame Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the point of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the Joy Con sensor rail's data cable ZIF connector.
    10. Nintendo Switch Front Frame Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    11. Nintendo Switch Front Frame Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the point of a spudger to pry up the black antenna cable straight up out of its socket on the motherboard.
    12. Nintendo Switch Front Frame Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the point of a spudger to pry up the white antenna cable straight up out of its socket on the motherboard.
    13. Nintendo Switch Front Frame Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your fingers or a pair of tweezers to pull the right speaker connector straight out of its socket on the motherboard.
      • Do not pull on the connector by the speaker wires. They're very thin and can easily snap off the connector.
    14. Nintendo Switch Front Frame Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your fingers or a pair of tweezers to pull the left speaker connector straight out of its socket on the motherboard.
    15. Nintendo Switch Front Frame Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the Joy Con sensor rail data cable ZIF connector.
    16. Nintendo Switch Front Frame Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a pair of tweezers to slide the Joy Con rail data cable straight out of its connector on the motherboard.
    17. Nintendo Switch Front Frame Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a JIS 00 driver to remove the following screws:
      • Four 2.5 mm screws
      • Two 3.1 mm screws
    18. Nintendo Switch Front Frame Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a spudger into a gap between the motherboard and the frame.
      • Carefully lift up the motherboard and remove it from the frame.
    1. Nintendo Switch Front Frame Replacement, Remove the Fan: crwdns2935265:043crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a JIS 00 driver to remove the three 4.8 mm screws securing the fan.
    2. Nintendo Switch Front Frame Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a pair of tweezers or your fingers to lift the fan straight up and remove it from the device.
      • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the rubber bushings) to the new part before installing.
    3. Nintendo Switch Front Frame Replacement, Remove the Right Joy Con Sensor Rail: crwdns2935265:045crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a JIS 00 driver to remove the four 3.7 mm screws securing the right Joy Con rail to the frame of the device.
      • These screws are torqued down and can be difficult to remove. To prevent them from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
    4. Nintendo Switch Front Frame Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the right Joy Con sensor rail.
      • Take care not to snag the rail's data cable on the device frame as you remove it.
    5. Nintendo Switch Front Frame Replacement, Remove the Left Joy Con Sensor Rail: crwdns2935265:047crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement, Remove the Left Joy Con Sensor Rail: crwdns2935265:047crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your fingers or a pair of tweezers to lift the battery connector up and out of the way of the Joy Con rail's data cable.
    6. Nintendo Switch Front Frame Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:048crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:048crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    7. Nintendo Switch Front Frame Replacement: crwdns2935265:049crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a JIS 00 driver to remove the four 3.7 mm screws securing the left Joy Con rail to the frame of the device.
    8. Nintendo Switch Front Frame Replacement: crwdns2935265:050crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:050crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the left Joy Con sensor rail from the device.
    9. Nintendo Switch Front Frame Replacement, Remove the Power and Volume Button Board: crwdns2935265:051crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the flat end of a spudger to pry up the taped down power/volume ribbon cable.
    10. Nintendo Switch Front Frame Replacement: crwdns2935265:052crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:052crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the power/volume board with a pair of blunt nose tweezers.
    11. Nintendo Switch Front Frame Replacement, Remove the Exterior Power and Volume Buttons: crwdns2935265:053crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the rubber conductive pad out with a pair of blunt nose tweezers.
    12. Nintendo Switch Front Frame Replacement: crwdns2935265:054crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:054crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the power and volume buttons out with a pair of blunt nose tweezers.
    13. Nintendo Switch Front Frame Replacement, Remove the WiFi Antenna: crwdns2935265:055crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement, Remove the WiFi Antenna: crwdns2935265:055crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement, Remove the WiFi Antenna: crwdns2935265:055crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Deroute the black coax cable from the midframe.
    14. Nintendo Switch Front Frame Replacement: crwdns2935265:056crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:056crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Continue following the wire, derouting it as you go.
    15. Nintendo Switch Front Frame Replacement: crwdns2935265:057crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:057crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry the metal barrel surrounding the coax up from the midframe.
    16. Nintendo Switch Front Frame Replacement: crwdns2935265:058crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:058crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grasp the WiFi antenna board with a pair of tweezers and lift straight up to remove it.
    17. Nintendo Switch Front Frame Replacement, Remove the Screen: crwdns2935265:059crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Heat an iOpener and apply it to the bottom edge of the screen for around two minutes to to help soften the adhesive.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device—the display and internal battery are both susceptible to heat damage.
    18. Nintendo Switch Front Frame Replacement: crwdns2935265:060crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:060crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:060crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Apply a suction cup to the bottom-left corner of the screen.
      • Pull up on the suction up with strong, steady force to create a gap.
      • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
      • Insert the point of an opening pick into the gap, making sure to only insert the pick about 5 mm.
    19. Nintendo Switch Front Frame Replacement: crwdns2935265:061crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:061crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:061crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide the opening pick along the bottom edge of the screen to slice the adhesive.
      • Leave the pick inserted to prevent the adhesive from re-adhering to the frame.
    20. Nintendo Switch Front Frame Replacement: crwdns2935265:062crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:062crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:062crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a second opening pick into the gap to the left of the first pick.
      • Slide the opening pick back towards the left side of the device.
      • Leave the opening pick inserted.
    21. Nintendo Switch Front Frame Replacement: crwdns2935265:063crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Heat the left edge of the screen for around two minutes to help soften the adhesive.
    22. Nintendo Switch Front Frame Replacement: crwdns2935265:064crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:064crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:064crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Continue sliding the opening pick around the bottom-left corner to slice the adhesive.
    23. Nintendo Switch Front Frame Replacement: crwdns2935265:065crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:065crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Continue sliding the opening pick along the left edge of the screen to slice to adhesive.
    24. Nintendo Switch Front Frame Replacement: crwdns2935265:066crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Heat the top edge of the screen for around two minutes to help soften the adhesive.
    25. Nintendo Switch Front Frame Replacement: crwdns2935265:067crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:067crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:067crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Continue sliding the opening pick around the top-left corner of the screen to slice the adhesive.
    26. Nintendo Switch Front Frame Replacement: crwdns2935265:068crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:068crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:068crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Continue sliding the opening pick along the top edge of the screen to slice the adhesive.
    27. Nintendo Switch Front Frame Replacement: crwdns2935265:069crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:069crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:069crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Heat the right edge of the screen for around two minutes to help soften the adhesive.
      • Place the flat end of a spudger into the gap along the left edge of the screen.
      • Carefully and slowly lift the left edge of the screen, opening it like a book.
    28. Nintendo Switch Front Frame Replacement: crwdns2935265:070crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:070crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:070crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the right edge of the screen straight off the device, threading the ribbon cables through the frame as you do so.
      • Take care not to snag any of the ribbon cables on the frame as you remove the screen.
      • You can reuse the screen adhesive if it is still sticky. Otherwise, replace the adhesive with double-sided tape such as Tesa tape.
    29. Nintendo Switch Front Frame Replacement, Remove the Front Frame: crwdns2935265:071crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four screws securing the front frame to the midframe.
    30. Nintendo Switch Front Frame Replacement: crwdns2935265:072crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:072crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Switch Front Frame Replacement: crwdns2935265:072crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the front edge of the frame then slide the frame up toward the top of the display to remove it.
crwdns2935229:029crwdne2935229:0
Jerry Wheeler
crwdns2935283:003/21/22crwdne2935283:0
102,572 crwdns2915208:0crwdne2915208:0
crwdns2935297:092crwdne2935297:0
What kind of adhesive is originally used and where to buy? don't really want to use tape...
GBG HNM - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Depending where you are, this vendor is selling precut adhesive for the screen to frame.
https://www.repairsuniverse.com/products...
Jerry Wheeler - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The guide does not mention how to remove the battery! Only how to unplug it!
Carson Froelich - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
That's because the battery does not need to be removed for this procedure.
The photos were taken during a midframe replacement where the battery had already been removed, which is why I placed a note at the beginning of the guide stating:
crwdns2936751:024crwdne2936751:0 41
crwdns2936753:07crwdne2936753:0 139
crwdns2936753:030crwdne2936753:0 639
crwdns2959996:0crwdne2959996:0 39,599
