If your Nintendo NES Advantage Model NES-026 game controller is not working properly, you may need to remove the back panel for disassembly to investigate the issue.
All you need is a spudger and a standard Phillips #0 screwdriver.
Please visit the device page for background information on the controller, if interested.
Remove the four sticky pads from the bottom of the device.
Remove the six 8 mm screws from the bottom of the device with a Phillips #0 screwdriver.
Use your hands to pull the back panel away from the controller.
