Nintendo GameCube Optical Drive Assembly Replacement
    1. Nintendo GameCube Optical Drive Assembly Replacement, Top Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement, Top Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement, Top Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Turn over the Gamecube so that the bottom side is facing up.
      • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
    2. Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
      • Move the GameCube so that the inside is facing upwards.
    1. Nintendo GameCube Optical Drive Assembly Replacement, Removing the back panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently press down on the clips located on either side of the back panel.
      • Carefully remove the back panel from the GameCube.
    2. Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unclip the controller ports at the front of the unit.
      • A ribbon cable (outlined in orange) is still attached to the unit. Do not disconnect this cable.
      • Controller ports are where the controllers plug into the game console, and are a half circular shape.
    3. Nintendo GameCube Optical Drive Assembly Replacement, Separate the casing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement, Separate the casing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • This step may not be necessary depending on your end goal
      • Use a Phillips #2 screwdriver to remove the two screws on the back of the control port.
      • Carefully separate the gray outer casing of the control port and the circuit board.
    1. Nintendo GameCube Optical Drive Assembly Replacement, Remove Nintendo GameCube Optical Drive Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement, Remove Nintendo GameCube Optical Drive Assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The left side of the unit contains the cooling fan and its housing.
      • Carefully remove the two screws attaching the cooling fan housing to the unit.
      • Do not detach the red and black cooling fan wire from the main unit. Boxed in orange.
    2. Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four Phillips #1 screws retaining the ground springs.
      • Carefully remove the ground springs from the main unit.
    3. Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The optical drive is secured to a metal plate.
      • Using a Phillips #2 screwdriver, unscrew the twelve screws that are around the outer edge of the optical drive.
    4. Nintendo GameCube Optical Drive Assembly Replacement, Remove the assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement, Remove the assembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement, Remove the assembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully separate the optical drive assembly from the rest of the GameCube unit.
      • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
      • The metal plate and the actual optical drive will remain attached.
    1. Nintendo GameCube Optical Drive Assembly Replacement, Optical Drive Assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement, Optical Drive Assembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement, Optical Drive Assembly: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • At this point, your optical drive assembly should be separated from your GameCube.
      • Flip the optical drive assembly upside down.
      • Remove the six screws with a Phillips #1 screwdriver.
      • Gently lift and remove the metal plate.
      • Be careful not to disturb the brown ribbon cable.
    2. Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the blue wire by gently pulling.
      • Don't pull on either the wire itself or the connector attached to the board.
      • Disconnect the brown cable. This is done by gently pulling the black tab away from the white plastic. This will loosen the tension on the brown cable, allowing it to slide away from the tab gently.
      • Remove the four Phillips #1 screws connecting the circuit board to the optical drive assembly.
      • The fourth screw is located behind the screwdriver in the third picture.
    3. Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Release the small clip holding the board down.
      • Gently remove the circuit board (the large green square) as shown in the three pictures.
      • DO NOT SEPARATE the red wire or the white ribbon cable connecting the circuit board to the metal plate.
      • Red Wire
      • White ribbon Cable
    4. Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a flathead screwdriver to carefully release the four plastic clips holding the drive assembly together.
      • Carefully use a screwdriver as leverage to unscrew and release the last clip.
    5. Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently lift the metal plate off the drive assembly.
      • Be careful not to sever the red wire or the white ribbon cable still attached to the two halves of the drive assembly.
      • Then, flip the two halves of the drive assembly upside down.
    6. Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a flathead screwdriver to release the two clips located on the back half of the drive assembly.
      • The final clip doesn't need to be released; the top half of the drive assembly will slide away from the lower half.
      • Finish removing the top half of the drive assembly from the base.
      • Be careful not to detach the red wire or the white ribbon cable still attached.
    7. Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo GameCube Optical Drive Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the top half of the drive assembly is detached, turn it upside down.
      • Using a Phillips #1 screwdriver, carefully remove the three final screws near the lens assembly bars.
      • Extract the final three screws and remove the lens assembly.
crwdns2935229:021crwdne2935229:0
mwbisson
crwdns2935283:011/05/09crwdne2935283:0
1,176 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-2, Maness Fall 2009 crwdns2935289:0Cal Poly, Team 6-2, Maness Fall 2009crwdne2935289:0
CPSU-MANESS-F09S6G2
crwdns2935297:096crwdne2935297:0
crwdns2947412:05crwdne2947412:0
What type of optical drive could I use to replace the one in said GameCube once I've broken it down?
Bob Marotta - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I found OEM parts (removed from other Game Cubes) available on Ebay. Just ordered the part for about $16.
erin clark - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Good walkthrough. My 8 year old completed this repair with minimal help from me. Thanks!
As a tech writer I just wanted to say our step by step instructions are spot on. Great Job
Jim Canfield - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 48
crwdns2936753:07crwdne2936753:0 209
crwdns2936753:030crwdne2936753:0 987
crwdns2942667:0crwdne2942667:0 83,800
