Nintendo GameCube Controller Z Button Replacement
  1. Nintendo GameCube Controller Z Button Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Z Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    For some reason, it was simpler to take the top half off, although it could be because it is most probably refurbished before
    Rukir Gaming - crwdns2934203:0crwdne2934203:0
  3. Nintendo GameCube Controller Z Button Replacement, Z Button: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo GameCube Controller Z Button Replacement, Z Button: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    So how do you put it back in like the replacement because I have a controller I'm working a junker my Friend gave me and I'm trying to fix it the z button doesn't work here it's a pelican wireless controller it's actually not to bad bulky but not bad
    Justin Sebastian - crwdns2934203:0crwdne2934203:0
Sean Michel
crwdns2935283:001/14/13crwdne2935283:0
2,562 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-44, Regan Winter 2013 crwdns2935289:0Cal Poly, Team 19-44, Regan Winter 2013crwdne2935289:0
CPSU-REGAN-W13S19G44
crwdns2935297:031crwdne2935297:0
My z button presses down and makes the click, but it does not actually send any input to the controller. How do you fix this?
Augustine Park - crwdns2934203:0crwdne2934203:0
So how do you put it back in like the replacement because I have a controller I'm working with a junker my Friend gave me and I'm trying to fix it the z button doesn't work here is a pic
My bad no pic it's a pelican wireless controller
Justin Sebastian -
How do you change the spring? I have replacement z buttons just no spring for them…
Gaf Epar - crwdns2934203:0crwdne2934203:0
Does that silver bar on the bottom of the Z button supposed to be there? My Z button does not have that, is it important for the button to have that?
Kevin Alaniz - crwdns2934203:0crwdne2934203:0
Does anyone know where to buy the actual button for the Z button? I can’t seem to find one where the pins are further apart up top and closer together towards the bottom of the button. I only see the opposite.
Haig Karakashian - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 110
crwdns2942667:0crwdne2942667:0 20,208
