Nintendo Entertainment System Disassembly
  1. Nintendo Entertainment System Disassembly, Remove Top Housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Entertainment System Disassembly, Remove Top Housing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove six 13.25mm Phillips screws on the bottom of the system.
    • The screws are recessed about 40mm.
    • Once all screws are removed, simply lift the bottom half away from the top housing.
  2. Nintendo Entertainment System Disassembly, Remove Top RF Shield: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Entertainment System Disassembly, Remove Top RF Shield: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Entertainment System Disassembly, Remove Top RF Shield: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove seven 13.25mm Phillips screws around the perimeter of the RF shield.
    • Lift the RF shield up and away from the system and place aside.
  3. Nintendo Entertainment System Disassembly, Remove Cartridge Tray: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Entertainment System Disassembly, Remove Cartridge Tray: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Entertainment System Disassembly, Remove Cartridge Tray: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four 13.25mm Phillips screws from the four corners of the cartridge tray.
    • Your system may only have two screws on the bottom
    • Remove two 17.25mm Phillips screws from the top of cartridge tray.
    • Once free, slide the cartridge tray towards you and then lift slightly in the front to remove.
  4. Nintendo Entertainment System Disassembly, Remove Motherboard Pt. 1: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Entertainment System Disassembly, Remove Motherboard Pt. 1: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Entertainment System Disassembly, Remove Motherboard Pt. 1: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove three 13.25mm Phillips screws to free the motherboard from the bottom housing.
    • Carefully lift the motherboard and turn it over to find the wired connections.
  5. Nintendo Entertainment System Disassembly, Remove Motherboard Pt. 2: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Entertainment System Disassembly, Remove Motherboard Pt. 2: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the wired connections from the motherboard.
    • Player 1 (Shorter wires)
    • Player 2 (Longer wires)
    • Power/Reset Buttons
  6. Nintendo Entertainment System Disassembly, Remove Bottom RF Shield: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Entertainment System Disassembly, Remove Bottom RF Shield: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The bottom RF shield is held on by tension around the expansion port. Lift the shield up and away from the motherboard.
  7. Nintendo Entertainment System Disassembly, Remove 72-Pin Connector: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Entertainment System Disassembly, Remove 72-Pin Connector: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the 72-Pin connector, apply force to each edge and slide the connector off the contacts on the motherboard.
  8. Nintendo Entertainment System Disassembly, Remove Power/Reset Buttons: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Entertainment System Disassembly, Remove Power/Reset Buttons: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 13.25mm Phillips screws from the button assembly. Lift slightly in the back and then up and away from the housing to remove.
  9. Nintendo Entertainment System Disassembly, Remove Controller Ports: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Entertainment System Disassembly, Remove Controller Ports: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Entertainment System Disassembly, Remove Controller Ports: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two 7.25mm Phillips screws from the bottom of the system. Lift the controller port faceplate up and away.
    • Remove the controller ports by feeding them through the port holes to the front of the housing.
    • When reassembling, Player 1 (Left) has shorter wires that Player 2 (Right).
  10. Nintendo Entertainment System Disassembly, Remove Plastic Door and Accent Pieces: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo Entertainment System Disassembly, Remove Plastic Door and Accent Pieces: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo Entertainment System Disassembly, Remove Plastic Door and Accent Pieces: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove seven 7.25mm small flathead screws from the inside of the top housing.
    • Two of these screws also hold a spring for the door. When reassembling, refer to the keyed shape of the plastic to orient these correctly.
  11. Nintendo Entertainment System Disassembly, Disassembly Complete!: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Entertainment System Disassembly, Disassembly Complete!: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Screw List
    • (19x) 13.25mm Phillips
    • (2x) 17.25mm Phillips
    • (2x) 7.25mm Phillips (Silver, large cap)
    • (7x) 7.25mm Flathead (Silver, small)
    Things can be torn down more. The audio/video housing.
    Anthony - crwdns2934203:0crwdne2934203:0
crwdns2935229:019crwdne2935229:0
Joe Shacar
crwdns2935283:006/01/21crwdne2935283:0
1,095 crwdns2915208:0crwdne2915208:0
Very well done easy to do and easier to follow.
rictic1 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 30
crwdns2936753:07crwdne2936753:0 204
crwdns2936753:030crwdne2936753:0 892
crwdns2942667:0crwdne2942667:0 25,958
