Nintendo DSi XL Volume Buttons Replacement
  1. Nintendo DSi XL Volume Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo DSi XL Volume Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Volume Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Volume Buttons Replacement, Lower Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo DSi XL Volume Buttons Replacement, Lower Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo DSi XL Volume Buttons Replacement, Lower Case: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Volume Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Volume Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo DSi XL Volume Buttons Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo DSi XL Volume Buttons Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Volume Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo DSi XL Volume Buttons Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Volume Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo DSi XL Volume Buttons Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Volume Buttons Replacement, Volume Control Switch: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the inside of the battery compartment, use the tip of a spudger to detach the metal latch securing the volume control switch in place.
    • The latch will only move about 1 mm.
  9. Nintendo DSi XL Volume Buttons Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo DSi XL Volume Buttons Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo DSi XL Volume Buttons Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the flat end of a spudger, remove the adhesive securing the volume control switch ribbon cable to the back of the battery compartment.
    • Using the flat of a spudger, pry the volume control switch straight up out of the lower case.
    • Remove the volume control switch from the DSi XL.
  10. Nintendo DSi XL Volume Buttons Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the flat end of a spudger, remove the volume control buttons from the metal backing bracket.
    • The bracket is attached by a strong adhesive. Work slowly and carefully, being sure to not damage the ribbon cable.
    • Volume control switch remains.
  11. Nintendo DSi XL Volume Buttons Replacement, Volume Buttons: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo DSi XL Volume Buttons Replacement, Volume Buttons: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo DSi XL Volume Buttons Replacement, Volume Buttons: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While pushing the volume buttons through their holes in the lower case, remove the buttons and their silicone pads with a pair of tweezers.
    • Work patiently and carefully as the silicone pad is easily torn.
    • Remove the buttons from the silicone pad.
Brett Hartt
crwdns2935283:004/12/10crwdne2935283:0
130,386 crwdns2915208:0crwdne2915208:0
crwdns2935297:0143crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,541crwdne2935297:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 107
crwdns2942667:0crwdne2942667:0 7,636
