Nintendo DSi XL Speakers Replacement
  1. Nintendo DSi XL Speakers Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo DSi XL Speakers Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
    rust/white powder built up on a screw and can’t unscrew it
    Eco - crwdns2934203:0crwdne2934203:0
  2. Nintendo DSi XL Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Speakers Replacement, Rear Bezel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo DSi XL Speakers Replacement, Rear Bezel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo DSi XL Speakers Replacement, Rear Bezel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a push pin to remove the four plastic screw covers on the front bezel.
  4. Nintendo DSi XL Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four Phillips screws securing the front bezel to the rear bezel.
  5. Nintendo DSi XL Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo DSi XL Speakers Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  6. Nintendo DSi XL Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo DSi XL Speakers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger into the gap between the front and rear bezel
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  7. Nintendo DSi XL Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  8. Nintendo DSi XL Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  9. Nintendo DSi XL Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to pry the rear camera off the rear bezel.
    • Remove the rear bezel.
  10. Nintendo DSi XL Speakers Replacement, Speakers: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to lift the antenna from the front bezel to make room for lifting the speaker cables up.
  11. Nintendo DSi XL Speakers Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to lift the right speaker from its housing in the front bezel.
  12. Nintendo DSi XL Speakers Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to lift the left speaker from its housing in the front bezel.
  13. Nintendo DSi XL Speakers Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo DSi XL Speakers Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • De-route the left speaker cable along the top edge of the upper LCD.
  14. Nintendo DSi XL Speakers Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the display slightly, and lift the LCD out of the front bezel.
    • Lay the LCD down next to the DSi XL.
    • Don't attempt to remove the LCD, it is still attached to the front bezel via the display data ribbon cable.
  15. Nintendo DSi XL Speakers Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the two solder joints to separate the speakers from the LCD.
    • Right Speaker
    • Left Speaker
    • For both speakers, the red wire (positive lead) is soldered to the left contact. The black wire (negative lead) is soldered to the right contact point.
    • For detailed instructions on how to solder this type of connection, see our guide for repairing soldered connections.
Matthew Newsom
crwdns2935283:001/05/10crwdne2935283:0
40,954 crwdns2915208:0crwdne2915208:0
crwdns2935297:067crwdne2935297:0
Thank you for this video but I need some more help cause I dont know if my problem are the speakers or the earphones jack how can I solve this just one clue i need thanks again
Josh - crwdns2934203:0crwdne2934203:0
In my case, it turned out there was nothing wrong with my speaker… one of the wires that feeds around the screen was bad.
Dave Horlick - crwdns2934203:0crwdne2934203:0
is there anyway of adding two more speaker?
vincent johnson - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,135
