This guide will explain how to replace the shoulder buttons on a DS Lite if they are sticking or not working properly.
The tools you’ll need for this task are:
- Spudger or other flat tool
- Screwdrivers
- Phillips
- Tri-wing
Use a Phillips #00 screwdriver to remove the screw securing the battery cover.
Use a spudger to pry out the battery.
Pry off the rubber feet.
Remove the seven screws securing the lower case:
Three tri-wing screws
One Phillips screw
Two gold Phillips screws
One black tri-wing screw
Carefully pry the bottom cover off.
Remove the shoulder buttons by pulling out the metal pegs that secure them to DS.
You can now access the micro-button component and replace or repair anything as needed.
To reassemble your device, follow the steps in reverse order after making your repair.
crwdns2935229:09crwdne2935229:0
crwdns2947412:05crwdne2947412:0
For anyone dealing with unresponsive shoulder buttons, I highly recommend watching this video guide;
https://www.youtube.com/watch?v=VnWdawXC...
Gabriel Branyiczky - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
たしかにそうですね!!!
kawagoe - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks, this was very helpful. The ifixit guide doesn't include the needed details of how to clean the button contact. This fixed my issue.
Travis Kirk - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
+1 on this! Didn't need to replace the button at all.
Isak - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
とても、わかりやすくて、しっかり修理できました!
