Nintendo DS Lite Buttons Replacement
    1. Nintendo DS Lite Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo DS Lite Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the Phillips screw securing the battery cover to the lower case.
      • The screw remains captive to the battery cover.
      • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
    2. Nintendo DS Lite Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
      • Remove the battery from the DS Lite.
    1. Nintendo DS Lite Buttons Replacement, Lower Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo DS Lite Buttons Replacement, Lower Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the tip of a spudger to pry both rubber feet off the DS Lite.
    2. Nintendo DS Lite Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the following screws securing the lower case to the body of the DS Lite:
      • Two 4.3 mm gold Phillips screws
      • One 3.9 mm black Tri-point screw
      • One 3.3 mm silver Phillips screw
      • Three 5.5 mm silver Tri-point screws
    3. Nintendo DS Lite Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo DS Lite Buttons Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo DS Lite Buttons Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the cover from the Game Pak slot before continuing.
      • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
      • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
      • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
    4. Nintendo DS Lite Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the lower case away from the rest of the DS Lite.
      • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
      • When re-assembling, make sure that power switch and volume sliders are properly aligned with the switches on the motherboard.
    1. Nintendo DS Lite Buttons Replacement, Trigger Buttons: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo DS Lite Buttons Replacement, Trigger Buttons: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift both trigger buttons out of the DS Lite.
      • The trigger buttons are held in very loosely by small metal pegs and springs. Don't lose track of these pieces.
      • The second picture shows the correct configuration of the trigger assembly for reassembly purposes.
    1. Nintendo DS Lite Buttons Replacement, Wi-Fi Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the flat edge of a spudger to pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
    2. Nintendo DS Lite Buttons Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the flat edge of a spudger to pry the Wi-Fi board connector straight up from its socket on the motherboard.
    3. Nintendo DS Lite Buttons Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the flat edge of a spudger to separate the right edge of the Wi-Fi board from the motherboard.
      • The Wi-Fi board is secured to the motherboard with a layer of adhesive.
      • Remove the Wi-Fi board from the DS Lite.
    1. Nintendo DS Lite Buttons Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the flat edge of a spudger to pry the microphone connector straight up from its socket on the motherboard.
    2. Nintendo DS Lite Buttons Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo DS Lite Buttons Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo DS Lite Buttons Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • In the following steps you must pull the antenna cable between the DS Lite game cartridge reader and motherboard. Pull slowly and stop when you feel resistance to avoid damaging the cable or motherboard.
      • Position the antenna cable with its connector facing up and away from the motherboard using a spudger to hold it down lightly in the gap between chips on the motherboard.
      • Slowly and carefully pull the antenna cable until the cable connector is under the DS Lite game cartridge reader.
      • Continue pulling the cable until the cable connector comes out from under the game cartridge reader on the right side.
      • When reassembling and attempting to feed the antenna cable back under the game cartridge reader, the cable may kink or become difficult to feed through. If so, try feeding a piece of thread through first; then, tie the thread to one end of the cable connector and pull it through, guiding it past any obstructions.
    3. Nintendo DS Lite Buttons Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo DS Lite Buttons Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your fingernail or the edge of a spudger to carefully flip up the touchscreen ribbon cable retaining flap.
      • Make sure you are flipping up the retaining flap, not the socket itself.
      • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
      • Do not lift the flap more than 90 degrees, or you will break it off.
    4. Nintendo DS Lite Buttons Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 3.4 mm Phillips screws securing the motherboard to the upper case.
    5. Nintendo DS Lite Buttons Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Open the display enough to use your finger to push the front edge of the motherboard up and away from the upper case.
      • Do not try to remove the motherboard, as it is still connected to the upper display via the upper LCD ribbon cable.
    6. Nintendo DS Lite Buttons Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo DS Lite Buttons Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your fingernail or the flat edge of a spudger to carefully flip up the upper LCD ribbon cable retaining flap.
      • Pull the motherboard away from the DS Lite to separate the upper LCD ribbon cable from its socket on the motherboard.
      • Remove the motherboard from the DS Lite.
      • Now you may open the retaining flap for the lower LCD screen in the same way and separate the lower LCD screen from the motherboard.
crwdns2935229:049crwdne2935229:0
Matthew Newsom
crwdns2935283:001/05/10crwdne2935283:0
42,976 crwdns2915208:0crwdne2915208:0
crwdns2935297:067crwdne2935297:0
crwdns2947412:013crwdne2947412:0
Your stupid tutorial stuffed up my ds
Ish - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello! Sorry to hear that. What were you trying to do and what are the symptoms? Maybe we can identify the problem.
Vlad Mocanu Alexandru - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Mine is stuffed up too, the lower screen is flashing once and then its turning back off... I did all just as the tutorial said :(
Johannes Stark - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
U havent connected the upper screen ribbon cable correctly, I had the same problem and reinserting it making sure it went in all the way fixed the issue
Alex Horvath - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello! I bought a white ds lite from a flea market and it came with the lower screen damaged and the buttons were not working correctly. I bought a couple of broken ds lites and used your guide, to clean the motherboard, change the membranes and the lower screen. Thank you very much! I was able to completely restore the device functionality. As an added bonus, I was able to clean some of the dirt that gathered under the transparent sides.
crwdns2936751:024crwdne2936751:0 37
crwdns2936753:07crwdne2936753:0 196
crwdns2936753:030crwdne2936753:0 857
crwdns2942667:0crwdne2942667:0 108,218
