Has your DS Lite battery stopped providing the game time you deserve? Replace the battery to free yourself from the wall charger.
Unscrew the Phillips screw securing the battery cover to the lower case.
Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
Remove the battery from the DS Lite.
crwdns2935229:046crwdne2935229:0
crwdns2944067:05crwdne2944067:0
Can you describe the type of screw and captive washer ?
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
Thanks but will a dsi battery work
My battery cover won’t come off.
Flip the console upside down and it will but don’t pull it will break hold it close to the console then slide it back
dead -
A Phillips #000 (PH000) seems to give a more secure fit (no slipping) than the stated Phillips #00.
Ritchie - crwdns2934203:0crwdne2934203:0
This will be good for mods
Matthew Bevins - crwdns2934203:0crwdne2934203:0
I'm having a problem getting the screw to unscrew. I have the right Phillips ( it was included with all the stuff I got this) Any tips. it doesn't look like the screw is spinning but i haven't played my Nintendo DS Lite for 3 years.
whittlegirls - crwdns2934203:0crwdne2934203:0
bonjour j’ai une petite question pour vous fais trés longtemps que j’ai pas utiliser mon nintendo ds lite et quand je le branche il allume 1 fois orange après il s’enteint même s’il est brancher ça veux tu dire qu’il faut que je change de batterie ? Merci
Marie-Julie Richer - crwdns2934203:0crwdne2934203:0
Soit un changement de batterie, soit la carte-mère a peut-être un court-circuit :/
Polaris -
