crwdns2959928:0crwdne2959928:0 ↓Has your DS Lite battery stopped providing the game time you deserve? Replace the battery to free yourself from the wall charger.
Unscrew the Phillips screw securing the battery cover to the lower case.
Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
Remove the battery from the DS Lite.
crwdns2935229:054crwdne2935229:0
Can you describe the type of screw and captive washer ?
Cornel Paraschiv - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
Tamela Kellogg - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks but will a dsi battery work
Zach - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
While a very late reply, someone else may find this useful.
In short, no. Not at all. The DS Lite Battery I own (Original) Is listed as
USG-003
3.7v
1000 mAH
3.7 Wh
Where as the DSi battery I own (Again, an original straight from my console) is listed as:
TWL-003
3.7v
840 mAH
3.1 Wh
While the same voltage and a slight difference in capacity, the DSi Battery is slightly longer and slimmer in width to the DS/DS Lite Battery and you will need to find a battery suited for the DS/DS Lite you're using. Many places will sell these batteries but do your research as not all of these are created equal.
kaelowynlee - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My battery cover won’t come off.
Jake - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
