Nintendo DS Back Panel Replacement
    1. Nintendo DS Back Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo DS Back Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo DS Back Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the cartridge from the console.
      • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
      • Remove the battery door.
      • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
    2. Nintendo DS Back Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
    3. Nintendo DS Back Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery from the Nintendo DS.
    1. Nintendo DS Back Panel Replacement, Back Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the seven 6.4mm Y00 screws located on the back.
      • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
    2. Nintendo DS Back Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo DS Back Panel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo DS Back Panel Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • With your hands, pry the back panel off the main case.
      • Separate the back from the front, and set it aside.
crwdns2935229:020crwdne2935229:0
dnguye26
crwdns2935283:010/28/09crwdne2935283:0
782 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-3, Maness Fall 2009 crwdns2935289:0Cal Poly, Team 18-3, Maness Fall 2009crwdne2935289:0
CPSU-MANESS-F09S18G3
Where do I get a nintendo DS gamepak?
Kayla Maison - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Kayla Maison , a gamepak is simply a GBA game.
Bob - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 49
crwdns2936753:030crwdne2936753:0 229
crwdns2942667:0crwdne2942667:0 21,937
