Nintendo 64 Motherboard Replacement
  1. Nintendo 64 Motherboard Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. Nintendo 64 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Nintendo 64 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Nintendo 64 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two front feet of the N64.
  5. Nintendo 64 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate to top side up and lift off top cover.
  6. Nintendo 64 Motherboard Replacement, Metal Plate: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 64 Motherboard Replacement, Metal Plate: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
  7. Nintendo 64 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 64 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  8. Nintendo 64 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  9. Nintendo 64 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  10. Nintendo 64 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the small metal bracket from the back of the expansion pack slot.
  11. Nintendo 64 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 64 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  12. Nintendo 64 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 64 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the small metal bracket behind the expansion slot using the spudger.
  13. Nintendo 64 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 64 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
  14. Nintendo 64 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift off and remove the metal plate as indicated in the example.
  15. Nintendo 64 Motherboard Replacement, Motherboard: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws indicated using the #1 Phillips screwdriver.
  16. Nintendo 64 Motherboard Replacement, Motherboard removal: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up and remove the motherboard.
crwdns2935229:039crwdne2935229:0
tonymag28
crwdns2935283:010/28/09crwdne2935283:0
2,264 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-4, Regan Fall 2009 crwdns2935289:0Cal Poly, Team 5-4, Regan Fall 2009crwdne2935289:0
CPSU-REGAN-F09S5G4
crwdns2931471:07crwdne2931471:0
crwdns2935297:020crwdne2935297:0
4.2mm doesn't seem right. When I looked to purchase all I saw was 4.5mm and now that I have one in my hand it seems to fit very precisely on the screws on my N64.
negroslim - crwdns2934203:0crwdne2934203:0
i got the second comment :whyy:
Sqwerks - crwdns2934203:0crwdne2934203:0
What are the symptoms of a bad motherboard?
Jon - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 75
crwdns2936753:030crwdne2936753:0 305
crwdns2942667:0crwdne2942667:0 67,500
