Nintendo 64 Rumble Pak Battery Replacement
crwdns2869540:0crwdne2869540:0: 5528
3
25
111
5,528
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2959986:0crwdne2959986:0: 3
crwdns2959982:03crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 1 - 10 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
Does your Rumble Pak no longer vibrate? Learn how to check for corrosion and replace the batteries in your Rumble Pak to continue enjoying the ultimate gaming experience.
    1. Nintendo 64  Rumble Pak Battery Replacement, Rumble Pak Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the Rumble Pak from the controller by pressing the release button and pulling the Rumble Pak out.
    2. Nintendo 64  Rumble Pak Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery cover from the Rumble Pak by pressing the tab and pulling the cover up.
    3. Nintendo 64  Rumble Pak Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Press each battery toward the spring, then pull toward you to remove the batteries from the Rumble Pak.
      • When inserting the new batteries, make sure the positive (+) end of the battery touches the flat piece, and the negative (-) end touches the spring.
    4. Nintendo 64  Rumble Pak Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 64  Rumble Pak Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 64  Rumble Pak Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Check for corrosion around the springs and the flat plate where the batteries touch.
      • Do not touch the corrosion. It may be battery acid.
      • Use a flat head screwdriver to chisel away the corrosion, and use a Q-tip to wipe it clean.
      • Do not use water to wet the Q-tip, as water can damage the Rumble Pak.
Carly Bowen
crwdns2935283:007/20/15crwdne2935283:0
331 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 3-6, Rauch SU 2015 crwdns2935289:0Texas Tech, Team 3-6, Rauch SU 2015crwdne2935289:0
TTU-RAUCH-SU15S3G6
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 111
crwdns2959996:0crwdne2959996:0 5,528
