crwdns2959928:0crwdne2959928:0 ↓In order to reach the touchscreen of the Nintendo 3DS XL you will need to first remove the motherboard and accompanying parts. This guide will help you replace your touchscreen in no time!
Use a JIS 00 screwdriver to loosen the 4.2 mm‑long screws on the top edge of the back cover.
Use a plastic opening tool to pry off the clips securing the back cover, starting at the top corners and working your way down.
Use your hands to remove the back cover.
Insert the plastic opening tool into the opening located on the right side of the battery.
Pry the battery out of its recess and remove it.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
Remove the six 6.2 mm screws using a Phillips #00 screwdriver
Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #00 screwdriver.
With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
Disconnect the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
Completely remove the lower case from the rest of the device and set aside.
Position the device such that the game cartridge slot is located at the top.
Locate the circle pad on the right side of the device.
Remove the two 7.5 mm screws on the upper left and the bottom right corners.
Using a plastic opening tool pop off the circle pad joystick.
Using the flat head side of the spudger carefully lift up the retaining flap that attaches the circle pad ribbon to the motherboard.
Remove the ribbon and circle pad joystick.
Locate the IR board on the upper right side of the motherboard.
Remove the IR board with a plastic opening tool by inserting the tool below the IR board and gently prying up.
Using a plastic opening tool, pry off the Wi-Fi board.
Locate the volume switch on the right side of the motherboard next to the circle pad joystick.
Using tweezers, carefully remove the volume board from the casing. It will still be attached to the motherboard by a ribbon cable.
Using the flat head side of the spudger carefully lift up the flap that attaches the volume board ribbon to the motherboard.
Remove the volume board and set aside.
Remove the black plastic pieces from the lower left and right hand corners with either your fingers or tweezers.
Using the flat head side of the spudger carefully lift up the flaps that attach the two smaller ribbons to the motherboard.
Remove the ribbons from the flaps.
Using the flat head side of the spudger carefully lift up the flaps that attach the wider ribbons to the motherboard.
Remove the ribbons from the opened flaps.
Using the flat head side of the spudger carefully lift up the flap that attaches the ribbon to the motherboard.
Remove the ribbon from the flap.
Use a Phillips #00 screwdriver to remove ten 3.0 mm screws that are located around the face of the motherboard.
Carefully lift the board straight up just enough to clear the two plastic mounts located near the top corners of the cartridge slot.
Gently flip the motherboard over the top side.
Using the flat head side of the spudger carefully lift up the flap that attaches the wider ribbon on the upper right side to the motherboard.
Remove the ribbon from the opened flap.
Set the motherboard aside.
Open the device's hinge.
Gently press upward on the touchscreen until it separates from the casing.
Starting at the bottom right corner, insert the flat end of a spudger between the touch digitizer and LCD frame and gently pry the touchscreen off the LCD.
Insert the spudger into the top right corner between the two pieces and pry the touch digitizer off the LCD frame.
Repeat the above procedure for the remaining two corners to pry the touch digitizer off the LCD frame.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$2.95
Gently lift the touch digitizer up to completely separate it from the lower LCD.
crwdns2935229:069crwdne2935229:0
crwdns2947412:027crwdne2947412:0
what if you need to replace the screen on the top housing? what is it called.
kerriereed - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Is the bottom LCD screen of the Nintendo 3ds xl, the same as the one in the NEW Nintendo 3ds xl?
Looking for what part to buy.
markknobel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Bit old, but did you figure out the answer which to buy?
White - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Very detailed and easy to use step by step thanks. However, after reassembly after I switch the power button on it starts and then a flash and it trips out? Obviously a fault somewhere but not sure where to start.? Any thoughts appreciated.
Pete Mason - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
That's to do with a part this tutorial skips: you need to put some insulation between the new screen and the motherboard. That's what that orange film is on the back of the screen in the photos. When replacing, you can easily (carefully) remove that film and stick it onto the back of the new screen, no problem. Or you can put some other sort of adhesive to create some insulation between the screen and motherboard. Hope this helps.
Albert Wiltfong - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
