Nintendo 3DS XL Hinge/Midframe Replacement
  1. Nintendo 3DS XL Hinge/Midframe Replacement, Hinge/Midframe: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement, Hinge/Midframe: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the 3DS XL upside down.
  2. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4.2 mm screws from the back cover using a Phillips #00 screwdriver.
  3. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening tool to pry the cover loose and lift the back cover.
    • Caution: Make sure to lift the side with the screws up first as to not break hooks on the cover.
  4. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to remove the battery.
  5. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 6.2 mm screws from the back cover using a Phillips #00 screwdriver.
    • Remove the single 2.3 mm screw from the back cover using a Phillips #00 screwdriver.
  6. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hands to carefully remove the back cover at an angle, while keeping it connected to the top edge with caution regarding the ribbons.
  7. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to carefully detach both of the ribbon cables connected to the back cover.
  8. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 7.5 mm screws from the white plate.
    • Use your fingers to lift it off the space carefully.
  9. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to remove the small plastic circle from the opened space.
  10. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to carefully disconnect the small green rectangle (network board).
    If anybody is wondering what this green rectangle is, it's the WiFi-board.
    Blaxyy - crwdns2934203:0crwdne2934203:0
  11. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ten 3 mm screws from the motherboard with a Phillips #00 screwdriver.
  12. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the bottom right corner, remove the small plastic piece using a pair of tweezers.
  13. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the bottom left corner, remove the small plastic piece using a pair of tweezers.
  14. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With caution yet with slight force, use a pair of tweezers to pull and disconnect the ribbon cable from the latch on the top right corner.
    Actually, there are tiny hinges you can flip up to release the ribbon cables. Source: putting mine back together.
    Yvette Williams - crwdns2934203:0crwdne2934203:0
    +1 those flat ribbon connectors have flip tabs to secure/release the ribbon in the connector. Pulling out the ribbon without first flipping the tab up can cause damage to the connector and/or the ribbon cable. Recommended to flip the tab up before pulling out and with tab flipped up the force required to pull out the ribbon cable is much less.
    Alexsei thisDrop -
  15. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With caution yet with slight force, use a pair of tweezers to pull and disconnect the second ribbon cable from the latch on the top right corner.
  16. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With caution yet with slight force, use your hands to lift the screen and the green motherboard from the frame.
    • Caution: There is still a ribbon cable connected, so do not suddenly remove what was lifted.
  17. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With caution yet with slight force, use a pair of tweezers to pull and disconnect the ribbon cable at the hinge from the latch.
  18. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to disconnect the green rectangle (network board) from the small green cable.
    UMC receptacles can be tricky sometimes ( I have lifted the receptacle off a PCB before while trying to disconnect the coaxial (UMC) cable ). I now use tweezers to hold down the side fins (ground fins) of the receptacle on the PCB while pulling the cable at a slight angle to ensure that I do not accidentally lift the receptacle. If you accidentally pull off the receptacle it will require reworking to replace the connector.
    That said, if you are careful (and the cable head isn't glued into the receptacle - rare but can happen) you can often disconnect the cable without issue with just your fingers.
    There is a special tool made for safely disconnecting those cable/receptacle pairs.
    https://www.digikey.ca/en/products/detai... ("TOOL UMC EXTRACTION KEY" - DigiKey Part Number J984-ND)
    The tool pushes the cable head up off of the receptacle using the receptacle/PCB as a fulcrum.
    Alexsei thisDrop - crwdns2934203:0crwdne2934203:0
  19. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the 3DS XL right side up and open it.
  20. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to remove the small rubber squares from each corner of the front screen.
  21. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4.3 mm screws from the top screen using a Phillips #00 screwdriver.
  22. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hands to remove the top cover by pushing the cover horizontally away from the hinges, as to not break any plastic hooks.
  23. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the 3DS XL upside down and find the top left hinge.
    • In the small opening, use a small opening tool to push the small white plastic piece down towards the other hinge.
    • Caution: A decent amount of force will be needed to push it down, so use a small but sturdy object that can fit in the opening to push it down.
  24. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the small black plastic piece covering the hinge.
  25. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the small clear plastic piece from the hinge.
    • At this point you can remove the bottom frame from the left hinge using your hands.
    This is actually the right hinge.
    Kristina Riczu - crwdns2934203:0crwdne2934203:0
  26. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At the top right hinge, use your hands to carefully slide the ribbon cables through a small gap next to the hinge to remove them from the bottom frame.
    this is actually the left hinge.
  27. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to remove all buttons and rubber covers from the old frame and place them into the new frame.
FixitKevin
crwdns2935283:010/25/23crwdne2935283:0
547 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 4-9, Kershman Fall 2023 crwdns2935289:0CSU Los Angeles, Team 4-9, Kershman Fall 2023crwdne2935289:0
CSULA-KERSHMAN-F23S4G9
the photos leave a lot to be desired as I can't even see the small part that you take off to access the hinge itself unfortunately and now I am stuck with a completely taken apart 3ds lx that does not work without taking off the hinge.
Hailey Allen - crwdns2934203:0crwdne2934203:0
I've found a video on YouTube that goes over hinge replacements. I'm also trying to fix and replace my 3DS shell and I've used this as a tutorial.
https://youtu.be/ulwjPQ_Ntro?si=zTl-Gxgw...
Also when looking up 3DS replacements and tutorials read the comments! People go over a lot of support and their own personal experiences and tips.
UnsungBee -
I was wanging it violently last night but when i read this a brown tear ran down my leg :)
Mr. tough tip - crwdns2934203:0crwdne2934203:0
why do you need to share this
Enn -
crwdns2936751:024crwdne2936751:0 106
crwdns2936753:07crwdne2936753:0 566
crwdns2936753:030crwdne2936753:0 1,964
crwdns2942667:0crwdne2942667:0 20,749
