Nintendo 3DS XL Hinge/Midframe Replacement
  1. Nintendo 3DS XL Hinge/Midframe Replacement, Hinge/Midframe: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement, Hinge/Midframe: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the 3DS XL upside down.
  2. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4.2 mm screws from the back cover using a Phillips #00 screwdriver.
  3. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening tool to pry the cover loose and lift the back cover.
    • Caution: Make sure to lift the side with the screws up first as to not break hooks on the cover.
  4. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to remove the battery.
  5. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 6.2 mm screws from the back cover using a Phillips #00 screwdriver.
    • Remove the single 2.3 mm screw from the back cover using a Phillips #00 screwdriver.
  6. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hands to carefully remove the back cover at an angle, while keeping it connected to the top edge with caution regarding the ribbons.
  7. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to carefully detach both of the ribbon cables connected to the back cover.
  8. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 7.5 mm screws from the white plate.
    • Use your fingers to lift it off the space carefully.
  9. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to remove the small plastic circle from the opened space.
  10. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to carefully disconnect the small green rectangle (network board).
  11. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ten 3 mm screws from the motherboard with a Phillips #00 screwdriver.
  12. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the bottom right corner, remove the small plastic piece using a pair of tweezers.
  13. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the bottom left corner, remove the small plastic piece using a pair of tweezers.
  14. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With caution yet with slight force, use a pair of tweezers to pull and disconnect the ribbon cable from the latch on the top right corner.
  15. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With caution yet with slight force, use a pair of tweezers to pull and disconnect the second ribbon cable from the latch on the top right corner.
  16. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With caution yet with slight force, use your hands to lift the screen and the green motherboard from the frame.
    • Caution: There is still a ribbon cable connected, so do not suddenly remove what was lifted.
  17. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With caution yet with slight force, use a pair of tweezers to pull and disconnect the ribbon cable at the hinge from the latch.
  18. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to disconnect the green rectangle (network board) from the small green cable.
  19. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the 3DS XL right side up and open it.
  20. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to remove the small rubber squares from each corner of the front screen.
  21. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4.3 mm screws from the top screen using a Phillips #00 screwdriver.
  22. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hands to remove the top cover by pushing the cover horizontally away from the hinges, as to not break any plastic hooks.
  23. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the 3DS XL upside down and find the top left hinge.
    • In the small opening, use a small opening tool to push the small white plastic piece down towards the other hinge.
    • Caution: A decent amount of force will be needed to push it down, so use a small but sturdy object that can fit in the opening to push it down.
  24. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the small black plastic piece covering the hinge.
  25. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the small clear plastic piece from the hinge.
    • At this point you can remove the bottom frame from the left hinge using your hands.
  26. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At the top right hinge, use your hands to carefully slide the ribbon cables through a small gap next to the hinge to remove them from the bottom frame.
  27. Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Hinge/Midframe Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to remove all buttons and rubber covers from the old frame and place them into the new frame.
FixitKevin
crwdns2935283:010/25/23crwdne2935283:0
574 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 4-9, Kershman Fall 2023 crwdns2935289:0CSU Los Angeles, Team 4-9, Kershman Fall 2023crwdne2935289:0
CSULA-KERSHMAN-F23S4G9
the photos leave a lot to be desired as I can't even see the small part that you take off to access the hinge itself unfortunately and now I am stuck with a completely taken apart 3ds lx that does not work without taking off the hinge.
Hailey Allen - crwdns2934203:0crwdne2934203:0
I've found a video on YouTube that goes over hinge replacements. I'm also trying to fix and replace my 3DS shell and I've used this as a tutorial.
https://youtu.be/ulwjPQ_Ntro?si=zTl-Gxgw...
Also when looking up 3DS replacements and tutorials read the comments! People go over a lot of support and their own personal experiences and tips.
UnsungBee -
I was wanging it violently last night but when i read this a brown tear ran down my leg :)
Mr. tough tip - crwdns2934203:0crwdne2934203:0
why do you need to share this
Enn -
crwdns2936751:024crwdne2936751:0 47
crwdns2936753:07crwdne2936753:0 339
crwdns2936753:030crwdne2936753:0 1,702
crwdns2942667:0crwdne2942667:0 31,644
