Nintendo 3DS XL Battery Replacement
crwdns2869540:0crwdne2869540:0: 103 k
65
425
2 122
102 807
crwdns2955950:0crwdne2955950:0: 18
crwdns2960004:012crwdne2960004:0, crwdns2960008:06crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 66
crwdns2959974:066crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 13
crwdns2959982:013crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 5 - 35 crwdns2931277:0crwdne2931277:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
Is your battery having issues and need to be replaced? This guide will take you through the steps necessary to have a new battery in your Nintendo 3DS XL in no time!
crwdns2959948:0crwdne2959948:0
crwdns2959952:0crwdne2959952:0
    1. Nintendo 3DS XL Battery Replacement, Remove the back cover screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a JIS 00 screwdriver to loosen the 4.2 mm‑long screws on the top edge of the back cover.
      • The screws have locking washers that prevent the screws from falling out. Keep these in place.
    2. Nintendo 3DS XL Battery Replacement, Remove the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo 3DS XL Battery Replacement, Remove the back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a plastic opening tool to pry off the clips securing the back cover, starting at the top corners and working your way down.
      • Use your hands to keep the clips from reattaching.
      • Use your hands to remove the back cover.
    3. Nintendo 3DS XL Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nintendo 3DS XL Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the plastic opening tool into the opening located on the right side of the battery.
      • Pry the battery out of its recess and remove it.
After completing these steps, you can insert the new battery.
crwdns2935229:066crwdne2935229:0
Charlene Donlon
crwdns2935283:004/08/14crwdne2935283:0
11 322 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-13, Regan Spring 2014 crwdns2935289:0Cal Poly, Team 9-13, Regan Spring 2014crwdne2935289:0
CPSU-REGAN-S14S9G13
crwdns2935297:096crwdne2935297:0
Time estimate: 3 - 9 hours Difficulty: Very difficult ??????
More like 30-90 seconds, and that's if you have to search for a screwdriver.
Tommy Lynch - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
机器无法开机怎么办?是电池的问题吗?
doanaruto - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
It should be noted that the bottom three clips on the bottom of the backplate can’t just be snapped in, they need to be slipped in, so when removing the backplate, it should be tiled away from the system and then pulled up from the bottom, and those three clips on the bottom should be the first clips in when you’re putting it back together, sliding them in with the backplate at an angle, and then the rest of the clips just snap in.
Cole Jackson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Just did this. For reasmbly I recommend putting the bottom/lower part of the case on first before you screw it back on.
Scott Vogel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 65
crwdns2936753:07crwdne2936753:0 425
crwdns2936753:030crwdne2936753:0 2,122
crwdns2959996:0crwdne2959996:0 102,807
